Oil (I think) in compressor outlet - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-10-2013, 08:31 AM Thread Starter
The big hoses that direct the turbo outlet air from the compressor side to the intercooler were bubbleing like a mini volcano. They obviously need replacing, but as I removed them I found traces of fluid (I think it's oil) exiting the compressor and into the intercooler. This fluid was the only reason I was able to visually see that the hoses were leaking (a good thing). But ..... it does not seem to me oil or anything else should be traveling along the induction system. I am still trying to figure out where I am very slowly loosing coolant. It was kinda messy, and looked like oil, but is there coolant passing through the turbo anywhere that could be leaking into the induction system? It does not seem the coolant would have enough pressure anywhere to overcome the pressures in the compressor.
If it is oil (and it seems like just a trace, enough to make a mess), where would it be comming from? What are my options?
Whoisjohngalt is offline
post #2 of 3 Old 09-10-2013, 09:19 AM
What you are seeing is probably from the ccv system with high crank case pressure it sometimes gets too much oil mist out of the valve cover/ccv.
A small amount of oil is normal.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 3 Old 09-11-2013, 12:46 PM Thread Starter
Thank you ,... I appreciate that.
