Turbo failure? exhaust leak? egr leak? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 09-09-2013, 10:46 AM Thread Starter
I've got a 2006 f250 it's got 221k miles original*turbo. Predator programmer. 4 to 5 inch straight pipe. The other day I drove truck and I heard the*turbo*whistling extremely loud, but only under the hood and under acceleration over 1000 rpm. The exhaust sounds as usual but in the cab and under hood very loud. At idle is normal sounding. When it is started up it runs a couple seconds then when you hear*turbo*kick in I hear a pfft sound with a slight squeak. I have no coolant leaks. I listened around and right at the compressor side ofturbo*will dang near keep your ears ringing for a few minutes. Most definitely sounds loudest directly inturbo. I also dont smell exhaust really or see much evidence of a leak to speak of. Its possible that I am not looking in correct spots also. Any info is greatly appreciated. I an taking it on a 800 mile trip with my camper in 3 weeks so I need to fix asap thanks again
caleb
Jonesboys310 is offline
post #2 of 2 Old 09-16-2013, 06:37 PM
nic2fast's Avatar
sounds like what i just fixed. the up pipes on those trucks are bad at cracking at the flexible portion of the pipe between the manifold and y pipe. mine was passenger side where the egr cooler is
99 F350 4x4 Crew Cab Duelly Flatbed
Automatic w John woods VB and HD converter
4:88 gears
Leveling kit
460,000 miles on truck 130k on motor
22.5 Peterbuilt wheels with 36" tires
Dp-tuner Chip
Gauges
4in Turbo Back Silverline Exh. into grand rock 6" mitercut stacks
Irate Diesel S366 turbo kit
Full Force diesel Stage 1 Injectors
DIY Intake
Terminator modded HPOP
Irate Diesel comp. fuel system with RR
Iron Bull Front Bumper with 12,5 winch
Reacon smoked cab lights and LED bed lights
nic2fast is offline
Tags
6.0 , loud , turbo , whistle
