PLEASE HELP!!! - Ford Powerstroke Diesel Forum
post #1 of 8 Old 09-08-2013, 05:28 PM Thread Starter
IBStrokinit's Avatar
PLEASE HELP!!!
2005 6.0 PS
replaced engine with long block. replaced injectors, glow plugs, head studs egr delete, oil cooler, and hpop icp irp. Went to start it and ran fine for like 3 minutes choked down and cut off. wont start back...Almost like its hydro locked. wont even turn over. Ive got 7000 in the engine now and still looks like I have to take to the Stealership to get it goin...Please help...only codes it gives is egr which I expect due to delete and P0278. PLEASE help...I cant see giving ford money to tell me I should have taken it to them first...THanks in advance!
IBStrokinit is offline
post #2 of 8 Old 09-08-2013, 05:37 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
Originally Posted by IBStrokinit View Post
2005 6.0 PS
Well i work at the stealership ty very much. when you replaced injectors did you lube seals before installing them?
Anyway if it hydrolocked take out glow plugs and turn it over to see what cylinder locked then see if it locked from fuel or coolant
2001 to 2017 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 31 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #3 of 8 Old 09-08-2013, 08:29 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 557 Post(s)
Garage
He is right^^
If you try to crank it over and its locked up you most likely have a injector run amuck and pulling the glow plugs is your next step to see what cylinder it drains out of......
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
4" SS exhaust
58K Miles on it
2000 Watts of McIntosh Bliss
mhatlen is offline
post #4 of 8 Old 09-09-2013, 07:36 AM Thread Starter
Thanks doing glow plugs this afternoon....so once narrowed down to which cylinder what is next step? Injectors are new remanned?
post #5 of 8 Old 09-09-2013, 08:09 AM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Ok im not being a jerk but the best part about this site is that you get to learn. So with this said what do you think your next step will be. Ill tell ya if your wrong so give it a shot.
A/C ASW A/W WINGS
post #6 of 8 Old 09-09-2013, 10:36 AM
twoicebergs's Avatar
Quoted: 47 Post(s)
There are a number of hydro-locked (aka fuel-locked) threads on the board to be searched out. Since you (I am assuming you and a maybe more knowledgeable helper) installed a long block and put injectors in it, I would further assume that all of the correct procedures were followed to ensure success. So you only have a few options when you find the guilty party; was it installer error (missing or damaged part, technique) or did the injector nozzle fail? Perhaps it isn't even related to the most probable cause!
As suggested, as your own mechanic you now have to be the detective as well or pay someone who can do it for you. Some would call it a fair market exchange of cash for work performed. It is only stealing if you don't agree to pay for it and your wallet is lighter after the fact, or the work is not performed.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #7 of 8 Old 09-09-2013, 02:52 PM Thread Starter
my guess is get new injector? maybe reman one done by a guy that was hungover and not put together right?
post #8 of 8 Old 09-09-2013, 03:05 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Figure out what cylinder is involvedvand what hydro locked it then make a decision.
A/C ASW A/W WINGS
