13lb of boost max!!! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-08-2013, 10:47 AM Thread Starter
Fordutility6.0's Avatar
Hey y'all it's me again about to do head studs due to overflow in the degass bottle and egr is already deleted but my issue lately is that the truck will only push about 13lb of boost no matter what I do which tune I use or what I'm pulling, any suggestions or ideas, also was reading about the ccv mod while I had it tore apart for the bulletproofing any suggestions on that and it's already got the 4"turbo back exhaust so where would the back pressure sensor be and why is it not throwing a code on the h&s tuner please help me this truck is about to drive me nuts!!!! And where is the "1/4" line from the intake to the Vogt sensor" I read that someone had bumped one and cracked it and that was the problem any help much appreciated!!
Fordutility6.0 is offline
post #2 of 5 Old 09-08-2013, 10:57 AM
JustinOOO9's Avatar
Quoted: 419 Post(s)
Garage
could be the vanes on turbo are stuck... if you have a monitor right down the vgt% cycle numbers when you first start your truck. a turbo takes couple of hours to remove and then about an hr to clean plenty of videos on youtube. plus a good time to install the updated oil feed and oil drain tubes while your in there for the turbo...
let us know the vgt duty cycle numbers off a monitor and the more knowledgeable guys can help ya more.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes,
currently-1999 F250 SBRB 4X4 First 7.3, 6.0 trans cooler made my muffler fall off
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #3 of 5 Old 09-08-2013, 11:03 AM Thread Starter
It doesn't give me vgt percent just boost psi but I did put the turbo on about 4k miles ago had some motor work done not to long ago (passenger side oil rail came loose under the valve cover and made terrible noise) so that's why I asked about the 1/4" tube that may be cracked or broken
post #4 of 5 Old 09-08-2013, 03:43 PM
william_ace's Avatar
Quoted: 2 Post(s)
Take the 1/4" line off you are talking about, and replace it. Also, with a toothpick or a bobby pin, clean out the nipple that goes into the intake. I bet there is some gunk built up in there.
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
post #5 of 5 Old 09-08-2013, 09:40 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 447 Post(s)
Garage
Also check the ebp sensor on drivers side exhaust manifold. Its valve cover high and a SS tube with a sensor pressure switch screwed into it. Pull it and blow it out and push a wire through it.
It is what the computer uses to control the vgt settings. If it plugs up it will not give you boost.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
