Is it head gaskets tho? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 09-05-2013, 06:28 PM Thread Starter
Tommyboy7777's Avatar
So I did a pressure test last year and I am building up to 15psi in cooling system when I stomp on it.... my question is I have no puking,no performance issues,no loss of coolant....no anything, so are my head gaskets cooked? What are other symptoms?
2006 CC XL Sport
6" Procomp lift
37" Kumho road venture MTKL 71's on 17" procomp 6001 series
4" MBRP stainless turbo back cat delete
Banks ram air intake and zoodad mod
Bulletproof EGR cooler
New OEM oil cooler
Rebuilt turbo
Sinister coolant filtration system
Dual steering stabilizer Skyjacker
skyjacker shocks all around
Edge insight CTS
6" in dash dvd
Delo CAT-EC1 coolant
Rotella T6 synthetic
motocraft filters
Tommyboy7777 is offline
post #2 of 8 Old 09-07-2013, 09:13 PM
Mine had a slight enough leak that there wasnt any smoke or performance issues. With a mild custom tune I would get to 20 psi, 18 with sct canned performance and 15 or so on stock. Did gaskets and studs a month or so ago and there was soot built up on the block around the cylinders where the coolant is supposed to flow. Definite leak with mine. When you do your test, get it to full temp, then slowly let out all the pressure, then close your cap again. You should be at 0 psi, now do a WOT 0-80, if your pressure builds quickly then youve got a leak. Dont know what you use to check but if you get a T barb and enough hose to zip tie to your mirror, you can use a band clamp around the threads of a dial tire pressure gauge($8 for a 0-40 psi gauge at autozone). Just unscrew the valve stem fitting. Keep the gauge higher than the barb to keep coolant out. After headstuds and gaskets I tried over and over doing a few miles of WOT and couldnt get above 11 psi.
468 HP & 873 Ft-Lbs
2005 F-350 SRW 4x4 CC Long Bed
SPD tune by Chris @ Truck Source Diesel
ARP Head Studs
3.5" DP to 4" Straight Pipe
Banks High Ram Air Intake
K&N CAI
Edge Evo CTS w/ Backup Camera to monitor
MTS HD Direct Drive Solenoid
Updated:
Standpipe & dummy plugs
Turbo feed & drain tubes
HPOP & IPR screens
Blue Spring
ajfrac is offline
post #3 of 8 Old 09-08-2013, 05:08 AM
No you don't have failed head gaskets YET. You are still operateing within specs but at the max edge. You are also not showing any of the other symptoms.
You do however have a cooling system problem that needs immediate resoloution.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #4 of 8 Old 09-08-2013, 10:01 AM
JustinOOO9's Avatar
Quoted: 583 Post(s)
Garage
hang on...
15psi is good but there is more to the test then just not exceeding the 16psi limit. most likely your HG are good but.....
1. why did you test them in first place?
2. did the pressure build really fast? or slow gradual rise--fast rise is bad but requires more testing- you want a slow and gradual rise.
3. once you built your pressure pull over and slowly release all the pressure and the fluid will expand and then tighten your cap and drive back home etc... once parked again see if any more pressure built up after the initial pressure release: little to no more pressure should of built up...
p.s. the test is only really accurate when your coolant is above 190 and your thermostat and gauges are working correctly.
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s, JW Vbody.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #5 of 8 Old 09-08-2013, 03:54 PM Thread Starter
What is the cooling system problem that needs immediate attention? I have ELC cat rated coolant, bulletproof EGR cooler and a year old oil cooler not to mention up till a month ago I had a coolant filter......what should I be concerned about dannyboy?
2006 CC XL Sport
6" Procomp lift
New OEM oil cooler
Rebuilt turbo
Edge insight CTS
6" in dash dvd
motocraft filters
post #6 of 8 Old 09-08-2013, 03:56 PM Thread Starter
[QUOTE=JustinOOO9;6541673]hang on...
p.s. the test is only really accurate when your coolant is above 190 and your thermostat and gauges are working correctly.[/QUOTE
It was more of a gradual build up, I cant remember if I was at 190 degrees operating temp tho, I don't think I was......the rise happened over roughly 30 seconds if that helps...
2006 CC XL Sport
6" Procomp lift
New OEM oil cooler
Rebuilt turbo
Edge insight CTS
6" in dash dvd
motocraft filters
post #7 of 8 Old 09-08-2013, 03:58 PM Thread Starter
I did T off coolant line and had gauge inside the cab, I think I might redo the test and make sure im at operating temp and do it a few times in a row
2006 CC XL Sport
6" Procomp lift
New OEM oil cooler
Rebuilt turbo
Edge insight CTS
6" in dash dvd
motocraft filters
post #8 of 8 Old 09-08-2013, 04:12 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
Ok you t off the line going into the side of the degas bottle. Second when you get down on it the pressure should go up a little then settle back down if it does this is your water pump moveing the coolant only. If it goes up then stays there then goes up again then then starts venting under boost with no smoke out exhaust this is head gaskets. If it vents and smokes white out exhaust its most likely a egr cooler with head gaskets to follow shortly down the road. Hope this helps
2001 to 2017 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 31 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
