Problems after head stud install - Ford Powerstroke Diesel Forum
post #1 of 17 Old 09-05-2013, 05:54 PM Thread Starter
deerhunter2007's Avatar
Just replaced hg and studs truck ran great before hg failure, when apart updated stc fitting and cleaned ipr valve reassembled and started now it runs rough and misses, ficm voltage is 48.7 when cranking. Checked fuel bowl for compression leaking into the fuel system no bubbles. Snap on motis won't link up to my pickup to test kinda stuck now as for ideas. Trucks an 06 with 124,000 miles studded with oem gaskets, powermax, innovative tunes and blue spring upgrade. Hot starts just runs like crap and is hazing out the tail pipe smells like fuel. Any help would be greatly appreciated.
Built by me!!
99.5
6 inch with 38x15.5x20s
AFE Stage 2
Farmboys 5inch turbo back
DP Tuned
Wicked Wheel
Boost, Pyro, Tranny Temp
Pioneer DVD
Treo 10"
Pioneer 6x8s
02 headlights
Tranny built
Custom traction bars
Protec Headache rack
Dual RedTop Optimas
deerhunter2007 is offline
post #2 of 17 Old 09-05-2013, 08:00 PM Thread Starter
Anyone????
Built by me!!
99.5
AFE Stage 2
DP Tuned
Wicked Wheel
Pioneer DVD
Treo 10"
Pioneer 6x8s
02 headlights
Tranny built
Dual RedTop Optimas
post #3 of 17 Old 09-06-2013, 08:44 AM
jtaylor75's Avatar
did you send the heads to the machine shop? did you reuse the old injector o-rings? what did you torque the injector hold down clamps to? also if it runs, have you let in run for 20 minutes to let the air out of the hpo system.
06 CCSB FX4 Lariat
Studded and Deleted, Warren 190/100s, Barder Stage 4, Built Trans, AIS Water/Meth, S&B intake, 4 inch Exhaust
Next:
A fuel system
jtaylor75 is offline
post #4 of 17 Old 09-06-2013, 01:18 PM Thread Starter
Heads were machined no cracks, it's ran for an hour and yes it's all torqued to proper specs
Built by me!!
99.5
AFE Stage 2
DP Tuned
Wicked Wheel
Pioneer DVD
Treo 10"
Pioneer 6x8s
02 headlights
Tranny built
Dual RedTop Optimas
post #5 of 17 Old 09-06-2013, 01:20 PM Thread Starter
New orings and copper washers from ford everything came from ford except studs
Built by me!!
99.5
AFE Stage 2
DP Tuned
Wicked Wheel
Pioneer DVD
Treo 10"
Pioneer 6x8s
02 headlights
Tranny built
Dual RedTop Optimas
post #6 of 17 Old 09-07-2013, 03:48 AM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 275 Post(s)
Make sure your FICM plugs are fully engaged
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW FOR SALE!!
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
post #7 of 17 Old 09-07-2013, 04:06 AM
usnavyad's Avatar
Feedback Score: 3 reviews
Sounds like from what ur saying possible over fueling hmmmm can u run a cycl under contribution test have all of your injectors been tested. I would also load the stock file PCM and try to run the truck.
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
post #8 of 17 Old 09-07-2013, 04:08 AM
usnavyad's Avatar
As for the scanner not hooking up om out the obd2 connector see if there is a short or u could use a spring loaded test light to see if u can pull power from the connector
GPDA's other shawn
usnavyad is offline
post #9 of 17 Old 09-07-2013, 04:21 AM Thread Starter
It's stock tuning, and I picked up a laptop obd2 scanner and it works with my truck. Going to say the snapon must have a problem. Ficm plugs are seated all the way I've triple checked all the connections I managed to pull a cylinder contribution code from #1 code was a p0263 guess I should probably start pullin it apart again...
Built by me!!
99.5
AFE Stage 2
DP Tuned
Wicked Wheel
Pioneer DVD
Treo 10"
Pioneer 6x8s
02 headlights
Tranny built
Dual RedTop Optimas
post #10 of 17 Old 09-07-2013, 04:25 AM
usnavyad's Avatar
I almost wonder if number #1 injector just happened to go aswell those things happen
GPDA's other shawn
usnavyad is offline
