Oil change now really rough running - Ford Powerstroke Diesel Forum
post #1 of 31 Old 09-05-2013, 11:36 AM Thread Starter
So I changed my oil on Monday and used what I've always used delo and ford filter. Started truck and ran like crap. Got really irritated drained oil and put in rotella. Still same issue. Now the truck barely idles. All was well before oil change. I'm thinking rev x or any other ideas?
05 F350 Crew Cab SRW
Blue Spring
Updated Oil Drain Tube
STC Fitting
Dashboss
EGT Probe
Sinister Coolant Filter
Leveled
15K Mobile Condo
Dom350 is offline
post #2 of 31 Old 09-05-2013, 11:43 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Maybe your oil change is unrelated and something actually went out. How is your ICP volts and IPR %? What about FICM volts?
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 31 Old 09-05-2013, 11:59 AM Thread Starter
Ficm is 48 I will post the other two when I get home. What should they be at idle?
Blue Spring
STC Fitting
Dashboss
EGT Probe
Leveled
15K Mobile Condo
Dom350 is offline
post #4 of 31 Old 09-05-2013, 03:58 PM Thread Starter
Oil change now really rough running-imageuploadedbyag-free1378425365.923542.jpg
Here are those numbers any idea?
Blue Spring
STC Fitting
Dashboss
EGT Probe
Leveled
15K Mobile Condo
Dom350 is offline
post #5 of 31 Old 09-05-2013, 04:12 PM
Lilfarmrboy's Avatar
Lilfarmrboy is offline
post #6 of 31 Old 09-05-2013, 05:38 PM
alaskan155's Avatar
Quoted: 65 Post(s)
did you prime the oil filter with oil? heard that will cause problems on a 7.3....
other than that im clueless.
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #7 of 31 Old 09-05-2013, 05:38 PM
977300's Avatar
Did you change the fuel filter at the same time? Might be an issue somehow.
97 F-Super Duty 5 speed...T&S Performance Chip. More upgrades to come.
95 F-Super Duty 5 speed. The current project.
94 Dodge 2500 SOLD!
94 Dodge 3500 Sold to buy Superduty parts
95 Dodge 3500 Sold to buy more Superduty parts.
03 Dodge 3500 SRW, 4 door, 4X4, Cummins
Banks exhaust. Transmission upgraded.
977300 is offline
post #8 of 31 Old 09-05-2013, 05:41 PM
Quoted: 8 Post(s)
Your numbers look good, do you have any trouble codes?
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #9 of 31 Old 09-05-2013, 05:54 PM
Check your spindle that goes in the middle of the filter be shure its not damaged or the plastic button in the top or the oil drain back valve.
You need to check the low oil pressure with a mechanical gauge and see if you have a min of 45 psi. You may be starving the hp oil system of oil.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #10 of 31 Old 09-05-2013, 06:23 PM Thread Starter
I just pulled the filter and the spindle looks good. No dtc present but around 25 mph it really stumbles. Looks like blue smoke when stumbling. Friggen driving me nuts
Blue Spring
STC Fitting
Dashboss
EGT Probe
Leveled
15K Mobile Condo
Dom350 is offline
