Injector Circuit Low- All 8 cylinders - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-04-2013, 09:23 PM Thread Starter
Dr. of Linemantology
quequeg37's Avatar
Keep getting codes for all the injectors having low curcuit . had that code once before on #1 but when i connected the harness plug into the injector plug mounted in the rocker box, i had forced it on 180 degrees out and pushed in 3 of the four pins. anyone had this before or have an idea. im guessing i need to check voltage at FICM. code says the FICM senses an opoen circuit to injectors. that leads me to beleive a plug has come loose. just did head gaskets (cab off) behind my shop 3 months ago but running fine since then. tried to attatch pic of my setup i used for cab off. did all the work by myself. took a while
[/SIGPIC]2004 F-350 Super Duty 4-DR./ 4X4 / Long Wheel Base/ FX-4 Package / Dulley / 4.10 Geared / 77,000 mi. / Lariat / Leather int./SCT Livewire Custom Tuned/ Cat & Muffler Deleted/custom EGR delete/arp head studs/black onyx head gaskets/stage 2 injectors/fauss fuel system/5" MBRP turbo back and exhaust/ all done by Russ Kennell at MAXIMUM DIESEL in San Jacinto, CA. scratch the Black Onyx gaskets. 5k later im back with the OEMs.
quequeg37 is offline
post #2 of 5 Old 09-04-2013, 09:33 PM
Yea I would say check the ficm. mine went south year or so ago
04 ccsb 4" exhaust. swamps 58 volt ficm with performance tune.zoodad mod. high idle mod,on board air, Sinister egr delete,Sinister coolant filter system,Sinister oil cooler,sct sf3, Sinister intake elbow
muddytrck18 is offline
post #3 of 5 Old 09-05-2013, 02:16 PM Thread Starter
quequeg37's Avatar
checked voltage on FICM. 48.5 volts dc.middle plug i dont think was all the way in cause it just kinda fell out. maybe problem solved
post #4 of 5 Old 09-19-2013, 05:42 PM Thread Starter
quequeg37's Avatar
the problem got worse. anyone know what the ficm voltage is supposed to be while runing?
post #5 of 5 Old 09-19-2013, 05:55 PM
Chapter Director
FICM voltage should be 48v when running.
2015 Tuxedo Black F350 6.7 CCSB 4WD PLATINUM
2006 White F350 6.0 CCLB 2WD
dowmace is offline
