Buying first diesel and having issues. - Ford Powerstroke Diesel Forum
post #1 of 24 Old 09-03-2013, 07:47 PM Thread Starter
Dieskyver's Avatar
I'm looking at an '06 6.0 with 46k miles on it. The tech at the dealership reported that it would need ficm 1/2 shell, turbo cleaning/replacement, and cac boots among other minor things. I check the degas bottle and it was a dark brown color but no oily, milky or chalky residue signs.
I drove the truck from the dealership across the street to the free way on ramp. As I hit 80 mph it started hissing bad. It didnt do it friday when i drove it and the salesman agreed there is a problem. I assumed it was either the turbo but sounded like an exhaust leak(to my untrained diesel ear). It increased with the throttle and while under a load at first but by the time i returned to dealership, it would do it while reving in park. I checked the degas cap and it looks like it is sealed. No oil or smoke from exhaust, degas or oil cap. I walked away tonight but the dealer is having the tech look at it and will update me sometime tomorrow.
I didn't notice the boost on the first test drive but seemed like it wasn't bad on the failure ride today. It didn't get past 20lb but I figured turbo need cleaning. Nothing unusual about boost levels.
I'll be buying this as is. They'er asking 21k. Any advise would be appreciated. This would be my first diesel(truck). Not afraid to learn but don't want to do it the hard way.
Dieskyver is offline
post #2 of 24 Old 09-03-2013, 08:21 PM
SickStroke6.0's Avatar
Feedback Score: 9 reviews
Thats WAY high for the issues it has. WAY high.
Blake
2013 F-150 CCSB Oxford White FX4 EcoBoost
Loaded with every option...
2008 F-250 CCSB Dark Copper King Ranch 6.4L FX4
4" MBRP Exhaust w/ Muffler (DPF/DOC Delete), Modded Stock Intake, H&S XRT Pro
SickStroke6.0 is offline
post #3 of 24 Old 09-04-2013, 04:12 AM Thread Starter
Dieskyver's Avatar
That's what I was thinking too but it is a 4x4 lariat dually. I don't mind doing the work/learning but buying turbos... And I don't know if the hissing noise is a problem that requires a cab removal solution.
Is the brownish color in the degas bottle a serious issue?
post #4 of 24 Old 09-04-2013, 05:02 AM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
Two years ago I paid 22k for my 2007 KR with no problems , They are ripping you off
sent from my Samsung S4
Shawn
2007 F-350 King Ranch FX4 LB Tow Boss DRW
SCT LiveWire, Atlas 80, WPE tunes, Blue Spring, Holders 175/30 injectors, KC Turbos Stage 2, Magnaflow Dual Tip 5", AMSOIL BMK-21, PMM Coolant Filter, Zoodad MOD, CCV MOD, AFE Pro Dry S OER Filter, Final Charge ELC, 08 style mirrors, SAP Diesel DD Solenoid, Derale Transmission Pan, Mishi CAC Tube and Boots, High Idle Mod, more to come..,
Qholic is offline
post #5 of 24 Old 09-04-2013, 05:08 AM
Heavy_GD's Avatar
Quoted: 1510 Post(s)
Feedback Score: 3 reviews
I just picked up an 06 CCSB 4x4 FX4/Lariat sunroof truck with a 4inch lift and 150k on an egr deleted otherwise unmolested engine for just over 15k.
If you are in a hurry you will pay more.
GD
Heavy_GD is offline
post #6 of 24 Old 09-04-2013, 05:16 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Ill jump on deck and say ya the 22k is a bit high. The good thing the issue's that you stated are all very easy diy projects. The ficm is as simple as pull and the get it repaired or get a new one. The turbo, this too iss is a pull and clean yourself.
The exhaust leak, well they can be a PIA to find and fix but you can do this as well.
But the biggest thing Id suggest is you get some type of monitor on the truck before you talk money. The dash guages are junk. You can spend $150 and save thousands.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 24 Old 09-04-2013, 06:34 AM Thread Starter
Dieskyver's Avatar
Nice rig Qh. I'm not in that big of a hurry but do need something. I figured with the low miles it would be worth talking to a dealer. I may offer 18 and settle for 19 but I'm not afraid to walk away at all. The brown film in the dega was my major concern but no one here has raised a major issue with it.
If I get it I'm sure you will hear more from me. Thanks for all the input and the price opinions.
post #8 of 24 Old 09-04-2013, 06:50 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
My degass bottle had this same brownish film. It wasnt oil, Im not sure it was kinda like rusted? But I tryed to wash it out with no luck. But I asked about the same thing and didnt get much back...I wondered if maybe the ford gold just stained it.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #9 of 24 Old 09-04-2013, 06:50 AM
Quoted: 2 Post(s)
I'd walk away. There's plenty of low mileage King Ranch and Lariat dually's out there for the same price. If the turbo is in need of cleaning then there's a possibility it could've overboosted at one time... not exactly a death sentence, but if someone kept driving it with an overboost condition then you're looking at head gaskets.
IIRC the casting sand Ford uses can stain degas bottles to that brownish color
I agree, get a monitor. I went with a buddy of mine to look at an 03' 6.0 Lariat FX4 CCSB. 154k miles for $8200. Truck was cosmetically great with normal interior wear for the year. It ran and drove just fine, and even though the truck supposedly had a new HPOP installed recently, the oil temp just kept rising. By the time we got back to the guy's house, it had a 22* delta. No telling how long he's been driving it like that too.
---Garret
2006 F250 6.0 XLT FX4 CCSB
S&B Intake
MBRP 4" straight pipe with 5" tip
Studded and deleted
CTS w/EGT
Atlas 40 and Looney Tuned
2002 F250 7.3 XL Reg Cab 2wd Sold!
1995 Ram 3500 Dually Reg cab 5.9 12v auto 2wd
Fordtrucktexan is offline
post #10 of 24 Old 09-04-2013, 08:34 AM Thread Starter
Dieskyver's Avatar
Sales guy called me back and said it was the exhaust manifold and they are fixing it. Would this be an indication that it has seen excessive heat? Ive read up pipe issues but do manifolds just fail? I'm leaning more towards walking now.
