Still hot no start after replacing all of this - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-03-2013, 08:01 AM Thread Starter
proamas's Avatar
Ok guys have the motor apart changing the oil cooler and took the valve covers off, and HPOP off air tested everything. I only hear a slight air noise in the HPOP. Nothing from the oil rails at all. Here is what I've done so far, new stand pipes, dummy plugs new oil rail on passanger side, ,new injector orings and seals, new nipple cup orings on drivers side.
So with all of that done I still have no start hot. I have the cover off still on the HPOP and used the test port on the pump to put air in. I'm at a loss, is there anyone of our members in the Tampa Florida area willing to come on by and take a look with me, maybe two eyes are better than one. The last thing I have is a new IPR Sensor.
Help please. I'm at a total loss.
proamas is offline
post #2 of 9 Old 09-03-2013, 09:10 PM
I believe youd want to apply air to where the icp sensor is. Ive never heard of using the test port. Are you applying 12v to the ipr to close it? If you dont it will send all the air through the ipr and you wont find a leak. You can get a pigtail for a 7.3L injector that will plug into the ipr to make it easier.
468 HP & 873 Ft-Lbs
2005 F-350 SRW 4x4 CC Long Bed
SPD tune by Chris @ Truck Source Diesel
ARP Head Studs
3.5" DP to 4" Straight Pipe
Banks High Ram Air Intake
K&N CAI
Edge Evo CTS w/ Backup Camera to monitor
MTS HD Direct Drive Solenoid
Updated:
Standpipe & dummy plugs
Turbo feed & drain tubes
HPOP & IPR screens
Blue Spring
ajfrac is offline
post #3 of 9 Old 12-05-2013, 04:01 AM Thread Starter
proamas's Avatar
Ok guys here it goes....... So after driving for around 5000 miles i started to have the same problem. Slow to start then hot no start. The other day i took the passanger side valve cover off because i discovered a leak on that side. Replaced all four injector top seals, put it back together and drove it for a week. Was starting fine, and then just a few days ago same problem, hot no start. Last night i again replaced two injector seals on the passenger side, that i had just replaced.
This morning side hot not start.
Has anyone seen bad injectors not bleeding off cause this problem???
Also i have not had the drivers side off again, but i dont hear any leaks from that side. Its hard to tell with that baffle on though.
One last note. I also replaced the dummy plug just in case with a new one i had in my garage.
2006 F250 Lariat
EGR Delete
SCT Livewire with Innovative tunes
Blue spring upgrade
Sinister Coolant filter
5" Diamond Eye SS exhaust
proamas is offline
post #4 of 9 Old 12-05-2013, 05:40 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
With many of the rail/injector seals failing you probably have rail/nipple seal leaks that actually end up destroying the rail/injector seals.
http://www.youtube.com/watch?v=_29Gt...etailpage#t=20
Oil Rail Nipple Cup Fixes
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #5 of 9 Old 12-05-2013, 08:08 AM Thread Starter
proamas's Avatar
I actually just replaced the passenger side oil rail with a new one from Ford. The nipple cups looked great and had not marks or any wearing.
But i still changed the nipple cup o-rings with heavy duty vition ones yesterday.
2006 F250 Lariat
EGR Delete
Blue spring upgrade
proamas is offline
post #6 of 9 Old 12-05-2013, 10:18 AM
Quoted: 46 Post(s)
So you are saying the nipple cup seals are all good, but you are replacing them again just because, or are they bad again and the injector seals are failing as well? Please remember you will see pulsing oil from the injector exhaust ports that may appear to be from the seals you are replacing.
I am running out of ideas except for your technique in replacing seals or installing the rail. Please post the ICP/IPR numbers.
Frank
Working for Toys
post #7 of 9 Old 12-05-2013, 10:36 AM Thread Starter
proamas's Avatar
I only changed the nipple cup orings because i had an extra set.
Here is exactly what happens. So i did a air test, replaced the injector seals that sounded like they where leaking. Kind of hard to tell. Then replaced the nipple orings. At this point though it was still leaking air from the empty rail. I added a little oil to make sure all the new seals had a nice coating of oil to the rail, then repeated air test and no air was leaking out anymore.
Im sure when i get home and do a air test hot, it will sound like air is rushing out of the passenger side valve cover. When i take the valve cover off, it sounds like the air is coming injectors, but i can never pinpoint the air leak, with my hand or see air rushing out.
2006 F250 Lariat
EGR Delete
Blue spring upgrade
proamas is offline
post #8 of 9 Old 12-08-2013, 09:18 PM Thread Starter
proamas's Avatar
Ok twoiceburgs
Ok, so today I did another leak test. Sounded like the passenger side was leaking again. I have a video of it.
I took the oil rail off. Put two dummy plugs in it to seal it and covered the injector cups. Applied air to it and I had zero leaks.
I then pulled each injector and put them on the rail. Each had a very small leak. I'm hoping this is normal. I will try to attach video when I get home.
My question is this, will I hear a very slight leak from the injectors venting? Or is this not normal. I used my son to help me plug the 4 holes on the oil rail to test the nipple orings. They were rock solid with zero leaks at 150psi.
I then inserted one injector at a time to listen to each. All 4 of them had a very small faint leak at 150psi and I mean small.
Then I put all four in at the same time and the leak was about the same. Very small as compared to when it was all still in the engine.
I started doing some research on injector manufacturers and all stated that you would hear small amounts of air passing by. Got me thinking....who knows if the injector was closed or open when it was shut off.
Also I looked into the design of the stand pipe. It has a one way open valve in it. Oil can go into the rail fast, but when air testing from icp port the air is really restricted going through a small oriface in the valve.
So now I'm thinking the noise even with the ipr closes could be coming from either the other oil rail venting into the crankcase because the drivers side valve cover is still on, or the oring at the STC fitting is blown out, or the yellow one under pump? Or lastly I have a failure at the pump itself. Hoping not that.
What are your thoughts???
2006 F250 Lariat
EGR Delete
Blue spring upgrade
proamas is offline
post #9 of 9 Old 12-10-2013, 06:48 AM
Sounds to me like the air is leaking past the spool valve and bleeding off through the spill ports. I've had to replace a few injectors because of this problem. When you put the rail on make sure there is some oil in it before you air test. The system isn't air tight but if there is oil in it the air shouldn't be able to push the oil through it. When you hear air leaking again remove the manifold and check the spill ports on the injectors. If there isn't any oil in them you found your leak. This has worked for me on more trucks than I can remember.
jpott62 is offline
