where to send injectors should I upgrade - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-03-2013, 05:03 AM Thread Starter
Davepnola's Avatar
have all my injectors out and visually can not see which cylinder caused the hydro lock .... So its has 103 k miles where should I send them and should I upgrade the tips for more performance ? I ran the truck low on fuel and after a fill up, after refueling truck missed like on one cylinder and was blowing black smoke ,,, by the time I got home, it was an old time locomotive pouring black smoke and making loud detonation bang...... I killed it and it stayed hydro locked until I removed all glow plugs ,,, So I pulled all injectors and really can not tell what cylinder was causing the problem visually.... Time to send them up suggestion would be helpful its 2003 excursion 6.0 stock
thanks
Davepnola is offline
post #2 of 3 Old 09-03-2013, 05:30 AM
twoicebergs's Avatar
Quoted: 47 Post(s)
If you have a few shop tools you can try this to find the bad nozzle.
http://www.youtube.com/watch?feature...LPKgPmx8#t=125
If you need to send them out, find a shop that has a Hartridge Test Flow Bench. Barring that, unless you want to modify them, change all 8 nozzles. It is easily done DIY.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 3 Old 09-03-2013, 05:34 AM Thread Starter
Davepnola's Avatar
link not working bad link
