What should oil temp read - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-02-2013, 03:46 PM Thread Starter
06 ford f350 my oil temp reads 222-225 coolant temp reads 190 driving 70-75 should oil temp be that high ? Reading off my livewire
Sent from AutoGuide.com App
Welder361 is offline
post #2 of 9 Old 09-02-2013, 03:47 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
That's too high. Sounds like you've got an oil cooler that's plugged.
dhanna6powerstroke is offline
post #3 of 9 Old 09-02-2013, 03:51 PM Thread Starter
Can the degas bottle puke cause of a plugged up oil cooler
post #4 of 9 Old 09-02-2013, 03:57 PM
Mod Newbie
Quoted: 20 Post(s)
Do you still have the stock EGR cooler?
post #5 of 9 Old 09-02-2013, 03:58 PM Thread Starter
Yes
post #6 of 9 Old 09-02-2013, 04:03 PM
Mod Newbie
Quoted: 20 Post(s)
Well, you possibly have 2 issues. When you have a restricted oil cooler, that restricts flow to the EGR cooler. When that happens, pressure builds in the cooling system which ruptures the EGR cooler. When that happens, you then have a possibility of a head gasket failure. Both of those will cause it to puke coolant from the degas bottle.
post #7 of 9 Old 09-02-2013, 04:12 PM Thread Starter
It's been like this for about 3 months if I drive It won't puke but if I get on the pedal it will puke. No loss in power and no white smoke
post #8 of 9 Old 09-02-2013, 04:14 PM
Mod Newbie
Quoted: 20 Post(s)
At a minimum you have cooler issues.
post #9 of 9 Old 09-02-2013, 04:20 PM Thread Starter
Thank you for your help
