HELP WITH HP OIL SYSTEM, - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-31-2013, 08:00 PM Thread Starter
whiteboy_77_77's Avatar
HEY THERE , IM HAVING A PROBLEM WITH HP OIL SYSTEM , RUNS GREAT WHEN COLD BUT AFTER ITS WARMED UP HAS A HARD TIME STARTING , IF I BURN DOWN THE HIGHWAY AND TURN THE TRUCK OFF , I WILL BARLY MAKE 350PSI BUT IF I LET IT SIT FOR ABOUT 15 MINS OR SO IT WILL SLOWLY CLIMB UNTILL IT STARTS. SO I DUG INTO IT TONIGHT, I PUT AIR TO THE OIL RAIL , COMMANED THE IPR SHUT AND PUT 150 LBS OF AIR TO IT FOR ABOUT 15 MINS ,THE ONLY SOUND I HERE IN IT GURGLING IN THE OILFILTER PRETTY BAD ,MY QUESTION IS IF THE OILFILTER NOISE IS NORMAL OR NOT , AND IF IT IS THEN ITS PROBLY LOOKIN LIKE THE HPOP RIGHT? AND IT DOES HAVE A BRAND NEW IPR
MY TRUCK IS A LATE BIULD 04.
THANKS MIKE.
Mike
2004 f350 5 inch lift 20x10 motometals w 38" toyo's
2002 f150 6 inch with dana 44
1991 bronco efi 460 4spd 16inch lift dana 60, sterling 10.25 and 40" boggers
whiteboy_77_77 is offline
post #2 of 5 Old 08-31-2013, 10:10 PM
Gurgleing in the filter houseing and no external leaks points to a pump problem. Since you have an 04 you have the failure prone sqashplate type pump. In 05 they went to a 4 piston type pump, more reliable and robust.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 5 Old 09-01-2013, 06:13 AM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
Feedback Score: 4 reviews
I would suspect the pump also. An 04 doesn't have the same style dummy plugs as an 05 and up. I've never seen one wear out on an early with the 1/2" square drive head.
For piece of mind I would replace the J-tube also.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #4 of 5 Old 09-01-2013, 09:03 AM Thread Starter
thank you guys I thought it was probly the pump too, just wanted some reassurance .ill put it back together thismorning with a new pump
Mike
post #5 of 5 Old 09-02-2013, 07:43 PM Thread Starter
Changed the pump , problem solved , that's for the help !
Mike
