Dies while driving still!!! - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-28-2013, 05:59 AM Thread Starter
proamas's Avatar
Well here I sit stranded on my way to work yet again. I'm ready to trade this thing in......
I originally started with changing the STC fitting a few weeks ago, when I took the cover off I noticed it had already been changed. So I put a new one in anyway. Then I changed dummy plugs, standpipes, injector orings and now the entire oil rail on the passenger side.
The nipple cups where bad and leaking, so it was necessary to change. The passenger side has zero leaks coming from it now, but still hot no start and also it dies while driving. Not as bad as before, I have a new oil cooler in the garage and will do that project this weekend, when it dies the oil temp is at 220. This is just driving no pulling, and the coolant temp is only 195-200.
I guess I'll pull the drivers side valve cover off and listen for leaks over there.
It's sounding more and more like a branch tube crack.
proamas is offline
post #2 of 4 Old 08-29-2013, 05:54 PM
I'm feeling your pain. I am starting and all but stalling around 1800 rpm when at consistent idle. I just replace the ICP. That didn't help. If I figure anything out I will keep you posted.
Suprob is offline
post #3 of 4 Old 10-04-2013, 02:01 PM
Truck has been at Ford for over a month....have you found anything out yet?
Suprob is offline
post #4 of 4 Old 10-04-2013, 08:24 PM
7.3, sorry for sayin
sean andreano is offline
