oil in degas bottle - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-27-2013, 01:28 PM Thread Starter
oil in degas bottle
is this due to the heads or egr cooler? motor has never ran hot. mechanic suggest its the head gasket. another says egr. truck has ran fine upto this point. 105000 miles on truck now. run diesel kleen in fuel religiously.
kenmx10 is offline
post #2 of 3 Old 08-27-2013, 01:44 PM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
your oil cooler ruptured. stop driving the truck and have the cooler replaced and delete the EGR cooler then flush system several times before refilling with coolant.
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx custom tuned, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Lighting, No Limit S2 Intake, Tinted, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #3 of 3 Old 08-27-2013, 01:45 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Any chance you have a monitor??????
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
