white smoke - Ford Powerstroke Diesel Forum
post #1 of 12 Old 08-27-2013, 07:29 AM Thread Starter
the black lemon's Avatar
white smoke
I've had my manual 6.0 for awhile and never really paid attention to it but one day i was waiting and i reved the engine and i did not see black smoke i saw white. i was not moving and had the parking brake on. but when i do heavy acceration its only black smoke coming out. is this a issue? or is that the way the engine keeps its self from over revving at idle. im first time diesil owner
the black lemon is offline
post #2 of 12 Old 08-28-2013, 10:22 AM Thread Starter
and my coolent level has yet to change and my oil is full still i had a friend rev it for me today and it just smells like the normal diesel exhaust anybody have any ideas or ever herd of anything like this? its completely factory besides bully dog tuner and straight pipe
post #3 of 12 Old 08-29-2013, 06:28 PM Thread Starter
i had a couple buddies look at it and they where saying i have a dirty hot side turbo and get a new air filter....any ideas on this?
post #4 of 12 Old 09-13-2013, 06:15 AM Thread Starter
i have a bully dog tuner and i notced when its set to no power it blows white smoke and what my thoughts are is when you have a gasser v8 with unequal length shorty heads cyclinders 4 and 8 burn lean so i think when the tuner is set to no power it is running lean. could this be the answer or sound legit enough to be a answer?
post #5 of 12 Old 09-13-2013, 06:23 AM
Warning: Diesel Only
Quoted: 7 Post(s)
is your egr deleted-if not could be bad egr-my 6.0L did this when i had a pin hole in my egr cooler. always good to do a egr delete.
2006 F-350 6.0L Powerstroke
138K Miles - 475 miles on rebuilt motor
Mod List:
Error: Your signature cannot be longer than 500 characters excluding BB code markup.
6.0bored is offline
post #6 of 12 Old 09-15-2013, 10:36 AM Thread Starter
the fluid level didnt lower when you had the hole though?
post #7 of 12 Old 09-15-2013, 03:46 PM
Quoted: 7 Post(s)
didn't notice-it was a mechanic that looked into the issue that told me it had a pin hole in it-i didn't catch onto it right away-wasn't doing much diagnostics myself at that point-wish i had an exact answer
does it do it mostly when the truck is "cold" or all the time?
Mine generally did it regularly when at stops
How many miles? What year? is your truck
Mod List:
6.0bored is offline
post #8 of 12 Old 09-16-2013, 04:28 PM Thread Starter
144k
and it only does it when im on the no power tune and have the turbo above 20psi
post #9 of 12 Old 09-17-2013, 04:52 AM
Quoted: 7 Post(s)
sounds like as you build pressure, it's causing the hole/crack to open-i would either delete or upgrade the egr cooler-something to try -unplug the egr valve and see how it acts. i wasn't all into the DIY when mine went but did some further research and it seams to point to the egr cooler being bad i would recommend a delete kit with that many miles-mine went at 60k miles (of coarse i had more strain b/c of plowing every winter and towing a substantial amount-and it wasn't even tuned just runnin stock)
Mod List:
6.0bored is offline
post #10 of 12 Old 09-17-2013, 09:42 AM Thread Starter
i think im gonna wait a little bit before i do it but i am gonna bullet proof it in the near future
