Too High of Fuel Pressure Issue ?? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 08-26-2013, 12:52 PM Thread Starter
5fifty's Avatar
Edge CTS is reading 98psi at idle. Drops to 95 on acceleration. When I shut the truck down the CTS read 35psi. Key in on position motor not running it is at 35psi.
No issues with truck as far as running . I drove it Saturday and it was normal.. Today it was reading 100PSI
I am taking reading from the cap on the filter and it is usually 58psi.
I know I should be reading from test port but I do not have the adapter yet.
I am hoping it is just the sender.
I talked to Edge and they are sending me a replacement sender.
Any thing else I can check in the meantime? I need to use the truck daily.
Any ideas?? TIA
2005 F-550 4x4 22.5's
Kelderman Air Ride
Bulletproof Diesel Remote Oil Cooler W/F550 Cooler
Bulletproof Diesel Billet Water Pump
Bulletproof Diesel Radiator
Dieselsite Wicked Wheel, Dieselsite Coolant Filter Kit
Warren Diesel 155/30, Bluespring Mod, 6.4 Banjo,
Updated STC, Turbo Feed and Drain Tubes,
PMM EGR Delete
SCT Tuner, Edge Insight w/EGT, Fuel and Oil Pressure
Tuned By MATT @ Gearhead Automotive Performance
5fifty is offline
post #2 of 8 Old 08-27-2013, 02:06 AM Thread Starter
5fifty's Avatar
TTT
Going to pull regulator apart tonight to see if it is is blocked possibly.
Any other suggestions?
Kelderman Air Ride
PMM EGR Delete
5fifty is offline
post #3 of 8 Old 08-27-2013, 10:43 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Sounds like the sensor to me… let us know what you find out.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #4 of 8 Old 08-27-2013, 10:59 AM Thread Starter
5fifty's Avatar
Thanks I will. I picked up a test kit from harbor freight and going to make a temporary gauge and get a reading out of the test port tonight to see where I am at. Then from there I might have to go into it further.
Kelderman Air Ride
PMM EGR Delete
5fifty is offline
post #5 of 8 Old 08-27-2013, 11:09 AM
Quoted: 8 Post(s)
I know that at 100 psi o rings and seals start becoming a serious problem.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #6 of 8 Old 08-27-2013, 04:00 PM Thread Starter
5fifty's Avatar
Yeah I have read that. When I noticed I was at 100 I turned around and went home. I had to drive about 15 miles cause I couldn't leave my excavator on the side of the road if I had to get towed.
Kelderman Air Ride
PMM EGR Delete
5fifty is offline
post #7 of 8 Old 08-28-2013, 05:40 PM Thread Starter
5fifty's Avatar
Update. ..
Confirmed that it was the sender that was bad. Got a oil test gauge from Harbor Freight and plumbed into the test port. Getting 60 psi at idle which is what I was normally getting.
Edge sent me a replacement and should be in tomorrow.
Kelderman Air Ride
PMM EGR Delete
5fifty is offline
post #8 of 8 Old 08-29-2013, 10:28 AM
Quoted: 8 Post(s)
Nice! Glad you found the problem.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
