Oil Filter takes 27 seconds to fill [VIDEO] - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-26-2013, 12:02 PM Thread Starter
Hello guys so I am working a few SLOW crank no start issues.
I bought this truck with a leaking egr cooler, and no start from my grandfather. I have not driven it or got it to start. I guess it hydrolocked on them and it has sat for a year. He had a shade tree mechanic look at it. He pulled the glow plugs and pumped the water out. But it still sat.
I will make another thread on all the stuff I have done to fix it. In the works of replacing all the common HPO system failures.
So my issue at hand is....I pulled the filter and held down on the button at the bottom of the filter housing. It took 20 seconds of cranking for the oil to begin to flow, and 7 seconds to fill the housing.
My oil level is at the correct amount. Could this be the result of a bad low pressure oil pump?
Drive it like you stole it, Or I will.
**ATTENTION SCREEN HOGS
If your signature block picture is bigger than most peoples post, maybe it's time to fix it. I suggest you tape a photo of your truck to your computer screen, then it only screws up your view.
gary6.0 is offline
post #2 of 5 Old 08-27-2013, 12:04 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
I'm not sure about your oil situation (seems like LPOP) but that starter sounds awful, how volts while cranking?
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 5 Old 08-27-2013, 12:11 PM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
dude that starter sounds like ****. batts low? worn starter?
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #4 of 5 Old 08-27-2013, 01:01 PM
Bump To Pass!!
toren302's Avatar
Quoted: 1608 Post(s)
You may also want to check the lpop relife valve. Easy to pull and might be stuck open. It is the 12mm allen plug right behind the crank pulley. It comes out with out pulley or belt removal.
Sent from AutoGuide.com App
toren302 is offline
post #5 of 5 Old 01-25-2014, 12:01 AM Thread Starter
Update:
I forgot I created this thread. But the lpop front cover was scorn and gouged. I replaced the cover, gears, seal/ring. Pressure is up. But gotta find the root cause of the failure. But that's already on another thread. Truck is in the shop now to find out the cause.
As for the starter... I had put a new starter on, sounded the same. Just bought another starter and dropped it off at the shop today. So maybe hopefully (but doubtful) that starter was the cause of the low rpm.
Thanks guys for all the advice .
gary6.0 is offline
