EOT and ECT range is odd - Ford Powerstroke Diesel Forum
post #1 of 11 Old 08-26-2013, 08:17 AM Thread Starter
Tommyboy7777's Avatar
So I had my oil cooler changed out 18 months ago,put in a bulletproof EGR cooler, did the coolant flush and change to ELC cat rated and up till last month my deltas were great (4-6* difference), ive noticed lately that the deltas are getting greater with the oil running hotter, by approx. 9-12*! I do regular oil changes, recently put in REV-X, ficm has just been redone. So im wondering why the oil is running a bit warmer. Should I drain coolant and re add some new stuff? I also had a coolant filter on for the first year after changing coolant and ive taken it off because a filter seized to the unit. Anyone know why my oil is running a bit warmer then normal? If oil cooler is starting to block should the coolant not run hotter?
2006 CC XL Sport
6" Procomp lift
37" Kumho road venture MTKL 71's on 17" procomp 6001 series
4" MBRP stainless turbo back cat delete
Banks ram air intake and zoodad mod
Bulletproof EGR cooler
New OEM oil cooler
Rebuilt turbo
Sinister coolant filtration system
Dual steering stabilizer Skyjacker
skyjacker shocks all around
Edge insight CTS
6" in dash dvd
Delo CAT-EC1 coolant
Rotella T6 synthetic
motocraft filters
Tommyboy7777 is offline
post #2 of 11 Old 08-26-2013, 08:40 AM
Oil temps shouldalways be higher than coolant temps. While you'r delta is about mid range you are well within the 15 deg. differential range or [delta]
What exactly are your concerns.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 11 Old 08-26-2013, 08:42 AM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
were you towing?
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #4 of 11 Old 08-26-2013, 05:36 PM Thread Starter
No, I wasn't towing. My concern is when I changed my oil cooler/EGR cooler/coolant 18 months ago, my deltas were always 4-7 degrees apart,now my oil is running hotter,deltas are growing,my concern is if that's a sign my cooling system is starting to act up
2006 CC XL Sport
6" Procomp lift
New OEM oil cooler
Rebuilt turbo
Edge insight CTS
6" in dash dvd
motocraft filters
post #5 of 11 Old 08-26-2013, 05:49 PM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
well towing makes it hotter. but your oil cooler is prolly plugging back up. but at 12* I wouldn't worry that much yet.
and just cause you run elc doesn't mean you cant clog your cooler again. cause it still happens.
Sold
LSP Group Threads
Jarrod B is offline
post #6 of 11 Old 08-27-2013, 11:50 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Oil cooler starting to plug up again… only thing you can do at this point is to monitor it closely and when it gets outa control, replace with another stock oil cooler or get the BPD oil cooler and never worry about it again.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #7 of 11 Old 08-27-2013, 03:58 PM
MDRhoads360587's Avatar
I just replaced my oil cooler last week and switched to CAT elc and Rotella T6 5w40. Cruising higway I run about 12* delta but in town or at idle I run 2-4* delta
2004 F-350 Lariat FX4 CCSB, Lariat, FX4
5% Tint All Around
MBRP 4" Straight Pipe
ARP Head Studs
Ford Gaskets
Sinister EGR Delete
New Oil Cooler
Cat ELC
Sinister Coolant Filter
Blue Spring
SCT Livewire
Shell Rotella T6 Synthetic Oil
Motorcraft Filters
MDRhoads360587 is offline
post #8 of 11 Old 08-27-2013, 04:08 PM
aswaff400's Avatar
my delta after coolant flush and new oil cooler with cat ec-1 coolant 8 months ago, my delta on the highway is about 5 degrees and on a trip last month towing a 3,800 lb boat and with a 400 lb ATV in the bed my delta was no more than 11 degrees at 65-70 mph
Aaron
'95 F150 XLT (SOLD), RCLB, 351w, 4-link SAS, 14 inch coilovers
'04 F250 Lariat 6.0L, FX4, CCSB, blue spring, egr delete, straight piped, CAT EC-1 coolant, sinister coolant filter, 2.5 inch leveled/lifted, RDS 60 gallon aux. tank, IDP tunes
a bunch of boats
aswaff400 is offline
post #9 of 11 Old 08-27-2013, 04:13 PM
JustinOOO9's Avatar
Quoted: 476 Post(s)
Garage
Did you do a flush before new coolers or after?
I think the ELC coolant runs differently then ford gold.. I had a huge rant because with ford gold i ran about 5 delta on highway then after 1. chemical flush, 2 studs, 3 delete, 4 new cooler i run about 9-10 deltas. but my truck has never ran better i think your fine man. when your oil gets up to 230 driving normally then get concerned i think at 245 or 253 oil tmep your engine "defuels" to save itself. run your truck and get a better coolant filter.
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake.
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #10 of 11 Old 08-31-2013, 06:22 PM Thread Starter
Ya I took off my sinister coolant filter because believe it or not I couldn't get the filter off the housing......I think ill get another filter housing again. And yes I did the flush before changing to new cooler
2006 CC XL Sport
6" Procomp lift
New OEM oil cooler
Rebuilt turbo
Edge insight CTS
6" in dash dvd
motocraft filters
