Stupid truck!!! Crazy no start issue! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-24-2013, 10:19 AM Thread Starter
bondsman's Avatar
Here we go... Bought a 05 F250 with 150k miles not running. It used to have a plow on it at some point and the only remnants are the large wires going from the front to the back, weird headlight wiring, and lots of rust.
Anyways, I tested it before purchase with my AE. FICM was 48v constantly, would crank over and IPR increased like it should, ICP did not build pressure. So, Brought it home.
Did the air test. Closed the IPR with AE, massive leak at hpop behind the gear. Bought and installed a replacement hpop and ipr. Still no start. Changed the starter because it was starting to drag. Still no start. Gave up on it for the evening.
Next morning, went to try a start with nothing hooked up to the truck and it would do nothing. No cranking, only a battery and airbag light would show on the dash, no noises when the key is turned on. Puzzled, I go grab the laptop and as soon as I plug in the AE dongle, everything lights up and it will turn over. Unplug the AE from the DLC and it is dead again. Plug it back in and it appears normal. Ran some tests and 2358 injectors failed. There were even codes for amismatched vin. Puzzled... I am assuming it is some sort of electrical short, wire unplugged, chafing issue. But, where to start??
05 F250 4x4 CC, 9.5" Rize/Icon, 38" Toyos, 20x12 Pacers, 5" MBRP, AFE stage 2, Cass 190s, Powermax, ELC w/filter, RCD EGR delete
04 Excursion 4x4, vacation bus
Project 1979 F250 6.0 powered in progress
bondsman is offline
post #2 of 6 Old 08-24-2013, 12:45 PM
Deer Creek's Avatar
Quoted: 51 Post(s)
I would start at your batteries and work your way back. Mine did something similar a while back and I traced it to one of the injector wires under the degas bottle. It was rubbed bare and shorting out and gave me a no start issue.
Someone posted on here that this problem usually occurs when the ground on the right side of the engine block comes loose or off.
Ryan
Deer Creek Farm
Carthage, NC. 28327
2004 F250 4X4 6.0 Diesel "War Wagon"
SRW Crew Cab Long Bed Pushing 305,000 Miles
Running 5w-40 T6 with RevX
FICM PHP Eco Tune
Blue Spring MOD
Warren 175/30 Injectors
EGR Deleted & Studded
Dieselsite Adrenaline HPOP
Coolant Filtration System
MBRP 4" Turbo Back Straight Pipe
Bullet Proof Diesel Water Pump
Ranch Hand's Legend Front & Rear Bumpers
2" Rough Country Lift
SCT X4 Tuner
Nitto Terra Grapler 285/75/16s
Deer Creek is offline
post #3 of 6 Old 08-24-2013, 01:02 PM Thread Starter
bondsman's Avatar
Thanks for the reply Ryan. I just needed a lil boost I guess. We bought this truck not running for CHEAP. I know it is electrical and that I just have to dig in it. At least I have a couple of spots to check first before I start looking at every inch of wiring.
bondsman is offline
post #4 of 6 Old 08-29-2013, 06:25 PM Thread Starter
bondsman's Avatar
A little update....
After a bunch of pinout tests, I cleaned 5 ground connections (one by abs module, one on firewall outboard of degas bottle, one on intake by the ficm, strap on passenger side above hvac box, one by emergency brake). Ended up disassembling the blue plug for the cluster and one wire at a time, I removed them and tightened up the hole so it made a tighter connection when plugged into the cluster.
The thing fired up eventually. Oil pressure registers on the dash, ICP build rather quickly now. The issue I am having right now is that it won't idle. If I press the gas a bit, it will run great. Sounds good, revs up fine. As soon as it approaches idle speed, it acts like you turn the key off. A little bit more troubleshooting and it should be up and running.
bondsman is offline
post #5 of 6 Old 08-31-2013, 08:27 AM Thread Starter
bondsman's Avatar
It is FIXED! Cam position sensor swapped out and it idles great now. Crazy that it would run with the bad one but not idle. Go figure..
bondsman is offline
post #6 of 6 Old 08-31-2013, 08:41 AM
6.0newb!'s Avatar
Quoted: 17 Post(s)
Wow congrats, crazy that such small issues can do all that, nice troubleshooting for sure
06 f-250 ECSB xlt fx4, MBRP 4" cool duals, AFE stage 2 intake, BPD water pump, BPD egr cooler, stc update, stand pipes, dummy plugs, blue spring, late 04 up pipe, wicked wheel 2, PMM coolant filter, Riff Raff ic boots, t6-5w40, Rotella elc, leveling kit with 350 blocks, Pro Comp pro runner shocks, full Powerstop z36 brakes, PHP ficm tuner, insight cts w/egt, SCT x3 with canned tunes...... for now
6.0newb! is offline
