Help! Won't start, oil pressure issue - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-23-2013, 02:54 PM Thread Starter
Truck shut off on me, no oil pressure on cranking. We changed the pump, still no go, we also changed the oil pressure sensor, regulator & a misfiring injector...... Still takes forever to build up pressure on cranking, my awesome mechanic is now stumped. Anybody have any other suggestions so we can get this fixed ASAP thanks. Same result hot or cold.
Powerstroke 16 is offline
post #2 of 9 Old 08-23-2013, 03:15 PM
Quoted: 727 Post(s)
Codes???
Which pump, lpop or HPOP? Which oil pressure sensor? Which regulator?
Corey@CNCFAB is offline
post #3 of 9 Old 08-23-2013, 03:19 PM Thread Starter
Hpop, no codes & regulator that is behind turbo on hpop, & sensor on passenger side valve cover
post #4 of 9 Old 08-23-2013, 08:02 PM
Quoted: 727 Post(s)
Cps? Are you seeing tach move while cranking?
post #5 of 9 Old 08-24-2013, 08:36 AM Thread Starter
Yes, it does
post #6 of 9 Old 08-24-2013, 09:06 AM
jimmyv13's Avatar
Quoted: 46 Post(s)
Feedback Score: 3 reviews
Send a message via AIM to jimmyv13 Send a message via Yahoo to jimmyv13
Stand pipes, dummy plugs or STC fitting.
2005 F250 CCSB Lariat FX4
4" MBRP Turbo Back*Sinister Coolant Filter*SRL+*'10 Tailgate*Dicad EGR delete*Premium EdFICM*Powerslot Rotors*Hawk Pads*Riffraff boots*DIY CCV*ARP's*'10 Tails*N-FAB Steps*'12 Rear Bumper*Dashboss*Pioneer DVD*'08 Trans Pan
*Bullitt y-pipe*'14 PE PF Mirrors*Fox 2.0 IFP*'08 Diff Cover
jimmyv13 is offline
post #7 of 9 Old 08-24-2013, 01:27 PM
bondsman's Avatar
Are you talking about low pressure oil reading on the dash is taking forever to build? If that is the case and you replaced everything (except the standpipes and dummy plugs), you might be looking at replacing the gerotors (lpop) and possibly the cover. It is external to the engine and behind the dampener on the crank. The oil pump gears can be bought separately and not as the kit (which includes the front engine cover). $60 vs $500+.
I am having a similar issue with no low pressure building but I think mine is faulty wiring. I have to stick a mechanical gauge where the low pressure sensor is and take a reading.
05 F250 4x4 CC, 9.5" Rize/Icon, 38" Toyos, 20x12 Pacers, 5" MBRP, AFE stage 2, Cass 190s, Powermax, ELC w/filter, RCD EGR delete
04 Excursion 4x4, vacation bus
Project 1979 F250 6.0 powered in progress
bondsman is offline
post #8 of 9 Old 08-24-2013, 05:27 PM Thread Starter
Low oil pressure is fine on dash, I am talking about high pressure
post #9 of 9 Old 08-25-2013, 02:58 AM
Keep in mind the dash gauge is only a switch has a 7 psi rateing, Ford says 45 psi min oil pressure to operate correctly. 45 and 7 psi are a long ways apart. Not much use in diagnostics.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
Tags
6.0 , no start , oil pressure
