Ole Smokin Issue - Ford Powerstroke Diesel Forum
post #1 of 22 Old 08-23-2013, 01:39 AM Thread Starter
Ole Smokin Issue
I tried posting over at DB and I am waiting on a response, so i thought i would try here and hopefully get some more answers. 2006 with 47,000 miles. 4in straight exhaust, RCD egr delete, new oil cooler, replaced stc fitting, stock tuned, coolant filter, edge insight. My delta was kinda erratic, so thats when I did the egr delete/oil cooler. Well Its been like 600 miles and i am still getting a lot of white smoke. The week after I put it back together it threw two codes for cylinder contribution on even numbered cylinders, I chocked that up to having air in the lines. After that week it never threw a code again. Average diffrence between temps now is like 5 degrees. I have been monitoring my levels and I dont see a drop in coolant at all. My edge insight shows 47.5 volts at start up and 48 when running. I took it to the dealer and he did a contribution test on it and didnt see any irregularities. He said one injector could be functioning at 60% but if all the others are at 100% it hides the bad one.. Didnt make sense to me but who knows. I am getting an average of like 12.4 mpg which seems kinda low to me. I would swear its my head gaskets but im not losing coolant. Only other thing I notice is while I am accelerating at around 2500 rpms I notice the needle start to flutter and I hear the exhaust waver (almost stutter). The smoke is white with maybe a blue tint, it kinda hangs around for a few seconds, and doesnt dissapear right away. I have no sense of smell, but my friend thought it kinda smelled like fuel but that is not confirmed. So is the tech right ?? am I just loosing an injector or two slowly ??? I'll buy a case of beer to whoever can troubleshoot this
Lockedwheels is offline
post #2 of 22 Old 08-23-2013, 02:21 AM
Quoted: 723 Post(s)
I'm not a 6.0l guru but it sounds to me like oil burning from an injector or two. Since your not loosing coolant.
Corey@CNCFAB is online now
post #3 of 22 Old 08-23-2013, 02:26 AM Thread Starter
So the technician could have been right? I just figured the contribution test should have shown something, and the fact that I am not throwing a code for an injector.
post #4 of 22 Old 08-23-2013, 03:30 AM
Is the smoke just coming off an idle? Are you loosing any oil? Reason I ask is mine does that also. Sit and idle and it will fog you out then speed engine up and it clears up and goes away. No coolant loss no oil loss. I'm thinking it is a cut injector o-ring.
06 F250 CC Lariat FX4 4x4, 4" MBRP exhaust, S&B Intake, SCANGAUGE II, SCT X3, Studded, EGR Delete
97 F250 EXT Cab Long Box PSD 4X4 Auto 4.10s FPR Shim 203` Stat Dana 60 Conversion Kitty Cat Gutted Superchips Tuner SOLD her and MISS her!!!
2007 Expedition Limited 5.7 4x4 Mama's ride all stock
1964 Mercury Monterey 54000 miles! IMMACULTE all ORIGINAL! passed down from my grandparents.
g-pippitt is offline
post #5 of 22 Old 08-23-2013, 03:35 AM
You may as well send hucorey his beer cause he is right. Relative compression and contribution are both an inferred calculation and can often be misleading.
Diesel is a dingy white to grayish smoke that lingers. Coolant is snow white and kinda fluffy looking it also abruptly disappears. Coule that with no loss of coolant and diesel is your better option.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #6 of 22 Old 08-23-2013, 04:55 AM
Quoted: 723 Post(s)
A cheaper way to check is add a bottle of RevX. 6.0's are notorious for stiction. If it gets better or even goes away, you will definitely know its injector related. You typically won't see a dramatic use in oil, unless its really bad. You may have to drive a 1k miles to drop a quart or so.
post #7 of 22 Old 08-23-2013, 05:24 AM
ngaraiderman's Avatar
Make that 2 4oz bottles of rev-x and stiction may go away. What kind of oil are you using. I've read that using rev-x or archoil and a good synthetic will help tremendously!
ngaraiderman is offline
post #8 of 22 Old 08-23-2013, 07:58 PM Thread Starter
I added two bottles of revx when I got done with my oil cooler... And I'm running.fully.synthetic xtreme diesel.
post #9 of 22 Old 08-23-2013, 08:00 PM Thread Starter
It smokes at idle and when I pull off.. I don't notice it when I am up to speed, but that could be because of the speed/wind
post #10 of 22 Old 08-24-2013, 06:09 AM
I can just sit in the driveway and rev it up and see the smoke disappear .
