Slow Start! - Ford Powerstroke Diesel Forum
post #1 of 2 Old 08-22-2013, 06:15 PM Thread Starter
Slow Start!
Hi Everyone! I just bought my first 2007 Ford 6.0 with 100k and its in completely stock form... I LOVE IT! My previous truck was a 2011 Ram 3500 with of course the 6.7 Cummins. My Questions is about its slow start. I have to hold the key while I crank it for 2 or 3 seconds before it starts. Is this normal? or a sign of something going out? I plan on having some fun with this truck (programmer, studs, egr delete, maybe turbo, etc..) but was thinking maybe I should be using my extra funds to solve this issue first. Any help would be greatly appreciated......
SprungYJ is offline
post #2 of 2 Old 08-24-2013, 05:24 AM
casper4203's Avatar
Well, I'm not an expert but I'm fixing the same thing and have learned a lot in the last month.
The high pressure oil system is designed to provide the oil pressure needed to operate the injectors. Their are sensors that detect when high enough pressure is present to tell the computer to fire the injectors. If the pressure is not held high enough from when it was shut off, the pump has to build it back up. This is a low volume / high pressure pump. That's when the extra cranking comes in.
The possible reason for the oil pressure issues are many. O-rings at the injector. O-rings at the high pressure oil rail. leaking fitting at the HPOP. Dummy plugs and stand-pipes. And a few other less common issues.
These are the issues I'm having. But the FICM and sluggish fuel system will also cause this.
If you don't already have something, Get an electronic monitoring system. I am using a Edge CTS. Set it to watch fuel pressure, FICM voltage, ICM and IPR%. Get it the numbers up before you start the engine and watch all these parameters and it will give you some clues as to what's going on. Then get back on here and talk it out. There are some "Youtube" videos that will help also.
Rich
EGR Delete
2005 Lariat CC/SB
5" Diamond Eye straight exh
Banks Ram-Air
Firetone Air-Bags
Edge Insight w/ fuel pres
and Pyro
Dummy plugs, Cat ELC
casper4203 is offline
