CKPO AND CMPO PROBLEMS!!!! - Ford Powerstroke Diesel Forum
post #1 of 2 Old 08-22-2013, 03:08 PM Thread Starter
OK, I accidentally sprayed water inside the FICM one day cleaning the engine off. It was fried so bad it had to be replaced. I put the new one on and I have codes for the crank position and cam position output circuits open. I went ahead and replaced both sensors just to do it for a quick and easy fix. Well, that wasn't the problem. With my scanner I checked to for "sync", and with the engine cranking it "synced" together. Has anyone else had the output circuit codes before or can someone point me in the right direction possibly with ohm readings for the circuits. Thanks.
JasonSeaton2004 is offline
post #2 of 2 Old 08-24-2013, 05:28 AM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
Off hand I would check your FICM connections they can be problematic to properly seat.
Shawn
2007 F-350 King Ranch FX4 LB Tow Boss DRW
SCT LiveWire, Atlas 80, WPE tunes, Blue Spring, Holders 175/30 injectors, KC Turbos Stage 2, Magnaflow Dual Tip 5", AMSOIL BMK-21, PMM Coolant Filter, Zoodad MOD, CCV MOD, AFE Pro Dry S OER Filter, Final Charge ELC, 08 style mirrors, SAP Diesel DD Solenoid, Derale Transmission Pan, Mishi CAC Tube and Boots, High Idle Mod, more to come..,
Qholic is online now
