06 no start - Ford Powerstroke Diesel Forum
post #1 of 11 Old 08-21-2013, 05:33 AM Thread Starter
06 no start
Ok, I'm new to this forum, I'm a 10 year independent shop tech. Not a ford owner but do have a strong ford customer base, anyway back on topic. I spent Trent the better half of last night trolling this forum and a few others trying to find a topic related and have had no luck finding one describing my problem so please forgive me if I have overlooked it,not the best at finding them. My problem is an 06 ford F250 6.0, had it down the street at the quick car they did an oil change and found a stripped drain plug, tapped the plug hole and installed an insert. Started the truck, it ran fine for a test drive and later when they went to move it around the parking lot, of course when the customer was called to come pick it up the truck started then immediately died has not tried to start sense. Started with the basics, have check and not getting any lpop oil pressure reading at the sensor plug on a Manuel gauge, I did the test of holding the drain back closed and it fills the filter housing quickly enough. After that I tried the air test on the hpop system and can't hear any leaks my problem I can't find anywhere else is on a whim I pulled the oil feed line for the turbo and nothing comes out while cranking for and extended period, could I possible have debri blocking the passages after the filter and just need to replace my housing? I have been unable to find a diagram showing the routes the oil takes and I have looked at the "bible" as it was called on one forum. Thank you for your help I chose this forum because it seemed to have the largest knowledge base and willing to help members
Ntma is offline
post #2 of 11 Old 08-21-2013, 02:48 PM
Since your oil was changed at one of those quicky lube type places no telling what filter you wound up with. The 6.0 really likes the motorcraft filter and cap.
The real problem comes in when the cap and filter doent match especially the wix high dome cap andjust about any other brand of filter. Wixes filter is almost 1" longer so if you should stick a motorcraft filter in a wix cap it wont fully depress the drain valve and you will loose oil to the pan as fast as it comes in.
Also check that the plastic tower is not cracked or theplastic valve on top the tower is intact. Another problem area.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 11 Old 08-21-2013, 05:24 PM Thread Starter
Thank you for the reply, I have already taken the spring out of the drain back to eliminate the problem of the aftermarket filter what is the issue with the top of the tower?
Ntma is offline
post #4 of 11 Old 08-21-2013, 05:46 PM
That is the oil filter bypass valve if it is broken or missing it will not build enough pressure and cut the amount of flow form the houseing so the hpop sump may run low or go dry. Never heard of anyone removeing the spring under the drain valve.
post #5 of 11 Old 08-21-2013, 07:01 PM Thread Starter
As I stated earlier I read and researched numerous forums and a few people had had the issues you described with aftermarket filters, by removing the spring the oil will not flow back to the pan with the filter removed unless you pull up on it thus if the filter isn't pushing down all the way such as one being to short then you still get the oil
Ntma is offline
post #6 of 11 Old 08-21-2013, 07:51 PM
Hmmm interessting I always just put the right filter and cap in but a workable soloution.
post #7 of 11 Old 08-21-2013, 11:17 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Do you have access to a scan gauge/monitor of some sorts? What is the HPOP doing? (Icp volts and IPR %) I'm confused on how your manual gauge isn't reading anything but yet your filling the oil filter housing quickly. Where is your gauge hooked to?
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #8 of 11 Old 08-22-2013, 12:43 AM
JustinOOO9's Avatar
Quoted: 521 Post(s)
Garage
there are a few things you 6.0 needs tpo have just to start... its a good idea to get a scangauge or edge or sct monitor...
1. your ICP- needs minimum 500psi
2. IPR voltage needs to be above 15% and under 85% to start (tuning can change the voltages)
-while cranking it should not go beloew 15% or above 85% or its HPOP issues
3. FICM syn and ficm volts above i believe 45 to start (properly) seen tons at 25vts start but run bad....
check your ipr voltage at crank and your icp reading...
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is online now
post #9 of 11 Old 08-22-2013, 08:47 AM
Quoted: 8 Post(s)
The truck should see 84% IPR while cranking... IPR should only be at 15% with the key on/engine off (not cranking)
Icp volts should be at .80 minimum to start (while cranking)
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #10 of 11 Old 08-22-2013, 09:10 AM Thread Starter
Manual gauge was hooked up to port where pressure gauge goes on at base of filter housing and to verify also tried at oil temp port, aswell as manually reading hpop pressure at valve cover I have a high pressure gauge just for ford power strokes, ficm voltage always above 45 V do not remember what ipr % was since last post have pulled turbo and got down to hpop ipr screens were intact haven't pulled hpop but can't find any outward signs of failure, also pulled lpop just to check it out gears and housing in great shape waiting on a filter housing to get to the shop so I can compare to make sure something wasn't damaged before it came to me
Ntma is offline
