IPR loose - Ford Powerstroke Diesel Forum
post #1 of 13 Old 08-20-2013, 07:41 PM Thread Starter
IPR loose
I have a 06 F350 6.0 that has been intermittently not starting, about every three weeks this would happen but it would start after about 10 to 15 minutes of trying. this morning it would not start and I never got it going. Tonight after work I hooked up a scanner and the IPR actual was way low (235psi) I removed the turbo and found the IPR connector ty wrapped to the IPR and found that the plastic part of the IPR that the connector plugs into is loose in the IPR. Would it be a safe bet to replace the IPR and get it running or should I dig deeper? I don't really want to pull the turbo again. Any thoughts would be appreciated. Am I right in thinking that the connector that is part of the IPR should not be loose?
Thanks.
Be1900mech is offline
post #2 of 13 Old 08-20-2013, 08:40 PM
The plastic plug should wiggle, the metal part is just a cover. While im not saying your ipr is good, that wiggling is normal. Being an 03, youre likely to experience hpo issues with a bad hpop, and the ipr would be prone to failure as well. Could be a plugged ipr screen too. There are several threads about how to test your hpo system to determine the leak.
468 HP & 873 Ft-Lbs
2005 F-350 SRW 4x4 CC Long Bed
SPD tune by Chris @ Truck Source Diesel
ARP Head Studs
3.5" DP to 4" Straight Pipe
Banks High Ram Air Intake
K&N CAI
Edge Evo CTS w/ Backup Camera to monitor
MTS HD Direct Drive Solenoid
Updated:
Standpipe & dummy plugs
Turbo feed & drain tubes
HPOP & IPR screens
Blue Spring
ajfrac is offline
post #3 of 13 Old 08-20-2013, 08:53 PM
510guy's Avatar
Quoted: 13 Post(s)
i just had mine changed, had between 220-300 psi.
2006 F350 Crew Cab Dually 6.0 PSD 6 spd, ARP, IPR Gen 2 with up pipe, BD Diesel boot kit with metal cold side intercooler tube
2008 f350 Reg cab SRW flat deck 5.4l for work
510guy is offline
post #4 of 13 Old 08-21-2013, 04:55 AM Thread Starter
Thanks for the info on the IPR. i have a 06 though not an 03 and from what i have read on hear the hpop is less likley to fail than earlier ones. I will ned to find a fitting so i can leak check the hpo system. Thanks for the reply.
post #5 of 13 Old 08-21-2013, 07:33 AM
I dont know how I mixed the 03 and 06 up. One thing to consider if youre doing the work yourself, is say you need to replace stc fitting, mighy as well update standpipe and dummy plugs and vice versa. It will prevent issues later on. Should be be able to get al the parts for that for around $150 from toulsey ford(renamed auto nation but you still can google toulsey)
468 HP & 873 Ft-Lbs
ARP Head Studs
K&N CAI
Updated:
HPOP & IPR screens
Blue Spring
ajfrac is offline
post #6 of 13 Old 08-21-2013, 07:40 AM
Quoted: 6 Post(s)
In most high pressure oil problems, my first step is to replace the IPR valve or at least remove the valve and check the screen for debris or damage. Even the slightest amount of debris can cause issues.
If the truck is a "no start hot" then the most likely answer is the dummy plugs or standpipes under the valve covers. Those are a pretty simple repair. If those are not the issue you may have a STC fitting failing causing a leak. That is a much more involved job.
05 Extended Cab FX4
SCT w/ Gearhead Tunes
Ble-Blah mod...
Edge Insight CTS w/EGT
PHP Tuned FICM-Hercules
a2elvis is offline
post #7 of 13 Old 08-21-2013, 11:53 AM Thread Starter
Thanks for the replys. Have new dummy plugs/standpipes and stc fitting on the way and will check the IPR screen as i do them. Thanks again.
post #8 of 13 Old 08-21-2013, 11:55 AM
Quoted: 6 Post(s)
No problem! BTW...
05 Extended Cab FX4
Ble-Blah mod...
a2elvis is offline
post #9 of 13 Old 08-21-2013, 04:30 PM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
Feedback Score: 4 reviews
I think when the IPR fails all the way open your pressure will still be 200-300 PSI as long as there are no other leaks.
I have changed a lot of bad IPRs and never thought once to see what pressure will generate when it's fully open. I just had my first IPR fail on the electronic side and that's what it made, about 230 psi. I know it was fully open because the solenoid was open internally.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #10 of 13 Old 08-28-2013, 04:52 AM Thread Starter
Update. Thanks to all that replied again. Got it running last night. When i got the hpop cover italready had a updated stc fitting, decided to change it anyway sinci i was there and had a new one. Put a wrench on the fitting and it was loose, weight of the wrench was all it took. Put it back together and after 4 20 second tries it fired up. Still takes about 10 seconds to startbutit starts.
