Died on HWY, No Crank - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-20-2013, 03:46 PM Thread Starter
Raudi's Avatar
I am experiencing this issue right now. I was driving down the highway and noticed I had suddenly lost power. I pulled over and verified the engine was still running. Then I tried to take off again. This time the engine turned off completely. I pulled off.
Troubleshooting begins:
1. Key on - no underhood activity, dash on, windows and other accessories work.
2. My scangauge is not getting data. (PCM suspect)
3. Key to start - starter will not engage.
- Had truck towed
4. key to start - started right up, had some jerky throttle response, then seemed normal
5. Took the batteries to autozone for testing. Both 12.5v @ about 85% charge, reinstalled
6. Inspected Fuse 22. (satisfactory)
7. Took the truck around the block. (tried) Upon accelerating the engine turned off again and I barely made it to a safe parking spot. Same indications as before. Walked home thinking it might be time/heat related.
8. Unplugged the center connector on the PCM. Truck turned over but no start.
9. Replugged the center connector on the PCM. No underhood activity, no crank
10. Switched out the relay for the PCM. No change.
11. Turned key to on position, got into the engine bay and started moving things. When I pushed in on the forward most FICM plug the underhood activity was restored. THe truck cranked and fired right up.
12. I intend to remove and expose as much of the wiring harness as possible this weekend and verify routing and insulation on the harness.
Hope this helps someone out there.
Raudi is offline
post #2 of 3 Old 08-20-2013, 04:18 PM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
- Had truck towed
Sounds like a loose connection on the ficm, you are on the right track. Check the ground terminal at the end of intake, it goes to the ficm i believe. Keep us updated with the progress.
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #3 of 3 Old 08-20-2013, 04:35 PM Thread Starter
Raudi's Avatar
Thanks for the quick response BlueDemon6.0. This is all taking place after last month's High Pressure Oil System debacle. I was trying everything and couldn't bring myself to pay for the HPOP. In the end that was the problem. Hey, but not almost every single o and d ring in my system has been replaced. :-)
This website, and a couple others, were a great resource for helping me through that. Hopefully I can get some information out there. Other threads on this seem to be mostly dead ended or hi-jacked.
I'll keep this posted. Hopefully tear in on Saturday morning.
Raudi is offline
