2006 6.0 has miss at highway speed at 1900 RPM - Ford Powerstroke Diesel Forum
post #1 of 1 Old 08-20-2013, 03:18 PM Thread Starter
Can some one help me I have a miss at 1900 RPM at 65 - 68 mph while pulling load with 2006 F350. Turbo has been replaced, # 4 injector replaced, new HPOP, new EGR cooler, New oil cooler, new IPR valve, Superchips 1805 programmer engine does not show any codes. I done a scan with scan tool no problems show up to indicate this miss. Miss is most prominent with programmer set to heavy tow and disappears when engine revs higher or if throttle is reduced. Did some trouble shooting and found that the miss disappears when the EBP sensor is disconnected so I replaced that. The miss came back when the sensor was plugged in again
fordlover12 is offline
