NEED HELP!!!!! CKP and CMP problems - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-17-2013, 02:17 PM Thread Starter
Ok guys this is going to be kinda long to explain what has all happened. OK, one night after work i pulled my truck to our wash bay at the shop and pressure washed the engine off. I cranked up the truck and it was running like ****. It was smoking and you could hear alot of diesel knock. I pulled the truck around the building and shut it off. I tried to start it back and the injectors would not come on. I checked power at the FICM fuse and it was good. I checked the codes and it said all 8 injectors were shorted to ground. I had a FICM that is good that come off a 2003 model and tried it. It would crank but run very very rough. I learned later that an 03' model will not work on my 2004 model. I then sent the FICM off to be repaired and the guy said it got water inside of it and it was burnt beyond repair. So, i bought a reman FICM and stuck it on. All injector codes went away but now it was saying that the cam and crank position sensors had open circuits and was hard to start like it had no fuel but you could hit it with either and it would run for a little bit then go to running bad again. I replaced both sensors just hoping when the FICM shorted it shorted the sensors as well. That didnt change anything what so ever. On my scanner where it says "FICM SYNC", it says "no". Should it say "yes" at all times or only when its running. Also, where all do i need to check as far as the circuits for both position sensors?? I know that was alot but i am in need of some desperate help. Thanks for looking.
JasonSeaton2004 is offline
post #2 of 10 Old 08-17-2013, 08:38 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
It can't give you any Sync info until the engine is cranking. Open circuits are usually connection issues. You could still have water or corrosion in a plug or a damaged wire. It sounds like you blasted the "do not blast" areas.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 10 Old 08-18-2013, 11:23 AM Thread Starter
If it says that it is synced together, does that mean tht the FICM has the correct programming for my year model truck?
post #4 of 10 Old 08-18-2013, 11:44 AM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
who's reman ficm?
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #5 of 10 Old 08-18-2013, 12:28 PM
jtaylor75's Avatar
what scanner are you using? AE dosn't have a high enough refresh rate to get accurate FICM sync signal. Usually on the AE it will say NO until the engine starts and switch to YES, then it will toggle between NO and YES.
I've also seen a tone wheel skip just slightly on the crankshaft and cause the same exact issues. Eventually it will lead to a no start. These kind of issues will drive you nuts.
06 CCSB FX4 Lariat
Studded and Deleted, Warren 190/100s, Barder Stage 4, Built Trans, AIS Water/Meth, S&B intake, 4 inch Exhaust
Next:
A fuel system
jtaylor75 is offline
post #6 of 10 Old 08-18-2013, 12:30 PM
john galt's Avatar
Quoted: 1185 Post(s)
I thought it sounded like water got into something as well, which i suppose is kinda obvious from the original post, the question is did something fry because of it or does he need to get in with something to get the water out and of where...
BUT as I am pretty new to these as well I kinda wanted to know what are the "DO NOT BLAST AREAS" you speak of? as I am kinda OCD about keeping my engine clean
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, sinister coolant filter(this is the ONLY pos sinister product that will ever be on my truck), riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #7 of 10 Old 08-19-2013, 06:28 AM
Quoted: 46 Post(s)
The Owner's Manual list the areas such as the FICM, GPCM, valve covers (injector connections), intake connections, and any other area with electrical connections. So, when using a high pressure washer, just about the whole motor area has some jeopardy.
Frank
Working for Toys
post #8 of 10 Old 08-19-2013, 01:57 PM
john galt's Avatar
allrighty then
so no washy washy maybe low pressure with a low pressure rinse
i just GOTTA try to get it cleaner cant fight that. lol
thanks for the heads up. perhaps i can get in with degreaser and some towels but i will never get it truly clean that way
post #9 of 10 Old 08-19-2013, 03:03 PM Thread Starter
I sent mine to a guy in Winona, Mn. (speedometerrepairguy.com) He said the FICM i sent him was so bad that he had to order one for me. I dont know where he go it or anything. The only thing i know about it is that is says "remanufactured" printed on the International label. Where all do the Crank and Cam sensor circuits run? I understand i got water in the FICM. I am fully aware of that. What i am getting at is, What all could fry considering the FICM burnt up??
post #10 of 10 Old 08-19-2013, 03:04 PM Thread Starter
I have a $2000 scanner from Matco. SPX is the people who made it.
