6.0 Misfire When Cold - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-17-2013, 06:57 AM Thread Starter
Guys,
First I have read a lot of thread regarding this but always seems to have bad injectors.
I have AE, have done a buzz test and a balance test. Everything seems good but;
- Is there a way to make the engine not compensate for a bad injector, therefore not having a perfect straight line as I have.
- ICP Voltage is right at .25V
- IPR is like a squarewave, within autoenginuity range but..What is it supposed to look like?
-FICM Voltage gives me consistent 48V
Symptoms are just like the other guys - Starts perfect, runs a bit like a dog until warmed up, Jerk and misfire like crazy at coolant temp between 160-178, and after runs fine.
1- Is there a way to do a contribution Test without the engine compensating?
2- Could it be dirty EGR, EBP, Turbo.....
Give me some ideas,
Thanks
Dayz
F250 - Lariat 06
179K
Dayz is offline
post #2 of 9 Old 08-20-2013, 04:51 AM Thread Starter
Updates;
I believe it does it from time to time when hot, very random and not often.
Can Someone pin me in the right direction? Troubleshouting guide or post? How do you find an oil leak? Which injector is failing if any?
I have Autoenginuity and getting better with it.
Thanks
Dayz
Dayz is offline
post #3 of 9 Old 08-20-2013, 11:29 AM
Chango's Avatar
Do a search for the word "stiction" there are a ton of threads on it and info on what you can do. I have had that issue for awhile now and have just been too lazy to do much about it because it runs like a champ 5 minutes down the road
Awesome thread on oil / cold start issues for 6.0 ---->
Troubleshooting a no Start Condition --->
Still using Ford Coolant? ---->
Chango is offline
post #4 of 9 Old 09-04-2013, 03:15 PM
Fordutility6.0's Avatar
Archoil archoil archoil
Fordutility6.0 is offline
post #5 of 9 Old 09-04-2013, 06:47 PM
c dog's Avatar
Mine started fine but ran rough for a few mins until it warmed up. I added Rev-x and it fixes the injector sictiation in a day or two. Now runs fine when cold. Search rev-x ALOT of people swear by it.
Sent from AutoGuide.com App
c dog is offline
post #6 of 9 Old 09-04-2013, 06:59 PM
Rev x is good but it's the old technology and its expensive archoil is nano technology search it you won't be disappointed I promise
post #7 of 9 Old 09-04-2013, 07:09 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Yup T6 and archoil will make a HUGE difference in cold starts!
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #8 of 9 Old 09-04-2013, 07:15 PM
Yes forgot the T6 that combination swear by it
post #9 of 9 Old 09-04-2013, 07:39 PM
jtaylor75's Avatar
Only the IDS can turn off FICM compensation during a contribution test. Are you getting any codes?
06 CCSB FX4 Lariat
Studded and Deleted, Warren 190/100s, Barder Stage 4, Built Trans, AIS Water/Meth, S&B intake, 4 inch Exhaust
Next:
A fuel system
jtaylor75 is offline
