Engine miss and p0263 code - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-16-2013, 01:28 PM Thread Starter
hughesis23's Avatar
When engine is under operating temp it has a hard miss/ buck but when the truck is warm you can only slightly hear that it has the miss and doesn't buck.. it seems to miss more the softer I am on the truck. Stillbseems to have plenty of power.. any ideas? P0263= cylinder 1 contribution/balance
hughesis23 is offline
post #2 of 10 Old 09-14-2013, 07:25 PM Thread Starter
hughesis23's Avatar
Thanks for the help guys
post #3 of 10 Old 09-14-2013, 07:28 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Majority of the time, it's a bad injector. Could also be harness problem also.
dhanna6powerstroke is offline
post #4 of 10 Old 09-14-2013, 07:31 PM Thread Starter
hughesis23's Avatar
Like the harness from ficm over or inside the valve cover? thanks
post #5 of 10 Old 09-14-2013, 07:37 PM
Mod Newbie
Quoted: 20 Post(s)
Could be where the harness comes out of the FICM but I was referring to the actual injector harness that plugs into each injector. I'd say you have a #1 injector going bad though. What year truck? How many miles?
post #6 of 10 Old 09-14-2013, 07:43 PM Thread Starter
hughesis23's Avatar
04 with early motor. 170k. as far as going about getting a new injector should I only buy ford parts or can i go to the local parts house? I have recently put in "Hot shot" supposed to be stiction eliminator but it says it could take up to 4k miles to fix. Another thing when I start my truck my ficm has declined down to 44v but its always up to 48-48.5 after the alternator kicks in. But we've load tested my batteries and they check out.
post #7 of 10 Old 09-14-2013, 07:47 PM
Mod Newbie
Quoted: 20 Post(s)
Hot shots will help with stiction but not a contribution issue. You need to be able to do a buzz test on the injectors. Each injector will click in sequence. Do you have Auto Enginuity or a scan tool with that capability?
post #8 of 10 Old 09-14-2013, 07:50 PM Thread Starter
hughesis23's Avatar
I don't guess. I just have my edge CTS... So it isn't from stiction. What exactly do they mean by contribution ?
post #9 of 10 Old 09-14-2013, 07:55 PM
Mod Newbie
Quoted: 20 Post(s)
Contribution means just that, that cylinder isn't contributing. Stiction is when the spool valve get varnished up and start to stick. Issue you're having is either a wiring issue or injector itself.
post #10 of 10 Old 09-14-2013, 08:01 PM Thread Starter
hughesis23's Avatar
OK I'll look into it thanks for the help
