P0272 injectors ??? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-15-2013, 04:13 PM Thread Starter
Smokinandstrokin250's Avatar
P0272 injectors ???
I have a code throwing p0272 cylinder/balance fault I've been reading on it is it the Ficm or injector the truck shakes like its misfiring around 1200-1700 rpms and now it's doing it from any range it idles funny and has loss of mpg and power trying to figure this problem already bought an injector but don't want to do a tear down if I don't have to I run diesel Kleen for the injectors also
Truck is stock except 4" turbo back , superchips ,and airaid cold air
Please help
Smokinandstrokin250 is offline
post #2 of 7 Old 08-15-2013, 08:34 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
It is quite possible it is only one injector, but it is more likely that you have 2 injectors that need replacing, but only one throwing a code. If you can, it may be worth getting a power balance or contribution test so you know before you change just the coded one.
If it is stiction only, try the fix in my sig.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 7 Old 08-16-2013, 04:15 AM Thread Starter
Where would I get that done at
post #4 of 7 Old 08-16-2013, 04:16 AM Thread Starter
post #5 of 7 Old 08-16-2013, 12:16 PM
Quoted: 46 Post(s)
A Ford dealership or at a shop with a good diagnostic tool. The IDS is best for this test.
Frank
Working for Toys
post #6 of 7 Old 08-16-2013, 09:13 PM Thread Starter
Ok thanks for the help will let u know what happens
post #7 of 7 Old 08-18-2013, 05:04 PM Thread Starter
I did some driving around after clearing the codes and cylinder 4 came back up so I went for it changed it today and its been good so far haven't drove it a lot though will stay posted thanks
Tags
balance , fault , ficm , injector , p0272
