05 6.0 no start - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-14-2013, 05:05 PM Thread Starter
bigpanther2004's Avatar
05 6.0 no start
Ok guys what we have is a 05 6.0 when we try to start it the truck will pop once likes its trying to fire then it will just continue to crack w/o popping again untill you stop cranking and try it again. We are watching the icp it spikes 1600 at first then levels out around 730. Tested the ficm stays at 48volts, cam and crank are in sync, ipr screen is clean and all intact, fuel pressure is also good any other ideas?
bigpanther2004 is offline
post #2 of 4 Old 08-16-2013, 06:21 AM Thread Starter
Problem solved
post #3 of 4 Old 08-20-2013, 02:44 PM
what was it. i was having kind of the same issues with my truck. but after a while it didnt pop or anything. it just cranked and cranked.
abielenberg0805 is offline
post #4 of 4 Old 08-20-2013, 02:51 PM Thread Starter
Pcm, can u watch ur icp? Make sure it has enough oil to run injectors if not prob a hpop issue
