No Start - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-13-2013, 09:27 AM Thread Starter
No Start
I have an '04 E450 box truck, 6.0. Was running fine, shut it off, came back an hour later, just cranked, no start. Had it towed home. Checked for blown fuse, all OK. Now won't even crank. Batteries are fine. Any ideas where to check??? Thanks!
BC1954 is offline
post #2 of 3 Old 08-13-2013, 09:52 AM
How did you determin battery state? Did you disconnect them from each other and load test them with a load tester.? Did you do a voltage/amp draw down test
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 3 Old 08-13-2013, 10:00 AM Thread Starter
Two new batteries. Was cranking fine before it just stopped cranking. Everything else works, lights, radio, etc.
BC1954 is offline
