Low icp pressure no start - Ford Powerstroke Diesel Forum
post #1 of 8 Old 08-13-2013, 06:16 AM Thread Starter
Exclamation Low icp pressure no start
First time posting.I have a 2005 6.0 with low icp presure 75 to 130.ipr duty cycle at 77 per cent .6,000 miles ago I replaced oil cooler egr cooler dummy plugs and stand pipes new stc fitting updated turbo drain tube and updated oil line to turbo.Truck ran great until yesterday.Started in the morning but took probably 10 sec to fire up.In the afternoon after sitting for and hour or two did not start on fist try but did start after cranking 2nd time.Drove home about seventy miles ran fine icp presure running between 580 and 2000.shut truck off when I got home and now no start.Think it it might be ipr valve?Looking for any ideas what might be wrong.Truck has 96,000 miles on it.
kandels is offline
post #2 of 8 Old 08-13-2013, 08:10 AM
jimmyv13's Avatar
Quoted: 46 Post(s)
Feedback Score: 3 reviews
Send a message via AIM to jimmyv13 Send a message via Yahoo to jimmyv13
After that many miles, it's probably not anything you repaired. I assume you did the stainless screen under the oil cooler.
What's your FICM V while cranking?
Have you unplugged the ICP and tried to start?
If those are in spec, I'd be looking towards the IPR.
2005 F250 CCSB Lariat FX4
4" MBRP Turbo Back*Sinister Coolant Filter*SRL+*'10 Tailgate*Dicad EGR delete*Premium EdFICM*Powerslot Rotors*Hawk Pads*Riffraff boots*DIY CCV*ARP's*'10 Tails*N-FAB Steps*'12 Rear Bumper*Dashboss*Pioneer DVD*'08 Trans Pan
*Bullitt y-pipe*'14 PE PF Mirrors*Fox 2.0 IFP*'08 Diff Cover
jimmyv13 is offline
post #3 of 8 Old 08-13-2013, 08:21 AM Thread Starter
ficm is 48.5 while cranking sync code changes to 1
kandels is offline
post #4 of 8 Old 08-13-2013, 08:23 AM Thread Starter
Yes new updated screen and cleaned valley was spotless.
kandels is offline
post #5 of 8 Old 08-14-2013, 05:33 PM Thread Starter
unplugged IPC still a nostart
kandels is offline
post #6 of 8 Old 08-15-2013, 05:44 AM
jimmyv13's Avatar
Quoted: 46 Post(s)
Are you running OEM oil filter and cap?
jimmyv13 is offline
post #7 of 8 Old 08-15-2013, 01:00 PM Thread Starter
yes original cap and only motorcraft filters are used in it.
kandels is offline
post #8 of 8 Old 08-17-2013, 11:15 AM Thread Starter
Pulled ipr screen was clean don't know wha todo next?
kandels is offline
