truck runs horribly - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-13-2013, 05:13 AM Thread Starter
truck runs horribly
so while idiling last week it started loping out of no where when i hooked my ae scanner up it came back with injector 1 circuit code so yesterday i replaced injector 1 truck ran great for the most part then this morning while driving to work it started falling on its face and would idle up to around 1000 without touching the acc and truck surges at around 1200 to 2000 all the time. I hooked it back up to the ae and found p2285 but then truck started running fine and this has not occured again truck is a 03 250 i monitered icp and icp desired and pids were within range no more than 10 apart anyone have any ideas also truck has 152000 and i replaced hpop, ipr and icp along with pigtail at around 120000 also replaced ficm around 146000 any input would be aprecitated
jthorton1101 is offline
post #2 of 5 Old 08-13-2013, 06:32 PM
Check the voltage for the FICM
JorgeCanek is offline
post #3 of 5 Old 09-12-2013, 06:15 AM
I am having the same trouble. I have the same code. I have an 03 excursion stock as far as I can tell. Bought it used through a dealer and was owned by the government before that. What have you been able to find.
Semper Fi! FUBAR.
03SilverEx6.0 is offline
post #4 of 5 Old 09-12-2013, 09:36 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
Have you tried unplugging that icp to see if default idles smooth?
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
post #5 of 5 Old 09-13-2013, 06:00 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
Since it is running well now it will be tough to diagnose. It is quite possible you were still dealing with air in the system and that was causing the problem. However, if there was no air in the system, with the idle increasing all on its own, that sounds like the ICP must have also be rising. The question is whether it was a cause or a symptom. If the ICP or wiring was giving false readings, the PCM would have the IPR opening and closing incorrectly. Conversely, the IPR could have been the culprit. Just a few things to consider if the problem resurfaces.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
Tags
6.0 advice , 6.0 diesel , 6.0 injector , runs rough , surging
