Bad HPOP? 6.0 demons - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-12-2013, 08:54 PM Thread Starter
Angry Bad HPOP? 6.0 demons
hello I have a 2005 f250 6.0 a couple weeks ago on a Tuesday it took about 1 full minute of cranking to start.. I drove it home from work that day ran fine once started next time took a little while to start drove about 30 miles and parked it. next day drove the spare car sat all day got home take it to the store ( took some time to start again ) get there shuit it off for about 45 minutes come out cranked until batteries died came tried to jump start plugged my mac mentor in only making about 25 lbs high oil psi at the time during cranking towed it home. But some background information the truck just clicked over to 170,000. At 119k the previous owner had an egr cooler failure and they pulled the heads off put head studs in it and basically put it all back together. At that time they also installed a delta force flashable programmer with the highest setting being 100hp, installed an EGR blockoff plate with an OEM egr cooler, a 4 inch lift, cold air intake and dual exhaust. I bought it with 143k and ever since ive owned it I have never ONCE been able to sense how long its going to take to start (80% of the time would fire up within 3 revolutions but could take 1 minute sometimes) usually when it wouldn't start I would let off after about 4 r 5 revolutions cycle the key hit it and it would usually fire after the 2nd r 3rd time doin this. I replaced the FICM because it was only putting out 28 volts upon cold starts and 43-45 hot cruising at 55mph. I took it off the road for the winter at 166k and tore it all apart I found the original standpipes and stc fitting (as worn out as they come) still installed (must have put them right back in when they did the studs) and also found when I took the b lockoff plate for the EGR cooler that it had blown another cooler. I noticed the whole 23k miles I owned the truck that the engine oil temp stayed a steady 230 with coolant always at 185. so I rebuilt the oil cooler, updated the STC fitting to the new one, reinstalled the stock HPOP, bought 8 reman injectors and installed them, reinstalled the stock IPR, reinstalled the stock oil rails and installed NEW updated dummy plugs and standpipes and switched over to rotella t synthetic 5w40. Fired the truck up it ran great for about 2 weeks then one day it started EXACTLY like it used to took about 1 mnute of cranking to start but then fired up and ran fine. then it started doing it about once every 3 days until the week it quit all together. Now I have it torn apart and with the ipr out of the hpop and everything in the system tight witht the ipr port being the only open spot.. I have NO oil coming out. Would this be the way to see if the pump is bad or is there an internal passage that the ipr blocks the oil from where its running right down thru the updated fitting into the branch tubes. I also took the icp sensor out with the ipr still in and cranked it and still no oil. PLEASE HELP
jwash7309 is offline
post #2 of 5 Old 08-13-2013, 05:20 AM
just curious is your lpop supplying good oil pressure
jthorton1101 is offline
post #3 of 5 Old 08-13-2013, 06:30 PM
Take off the oil filter cap, remove the filter, push the valve in the right with a screwdriver, turn the engine, does the oil comes up fast?...
JorgeCanek is offline
post #4 of 5 Old 08-13-2013, 07:54 PM Thread Starter
I can check tomorrow I was thinking about just taking the HPOP off and checking to see if oil is coming from there while cranking but I will try the oil filter method as well. Ive got to assume at this point it has good low oil pressure because it always ran at a good spot on the gauge (a needleswidth under 2/3 up the range on the gauge) **ALSO IN CASE I FORGOT TO MENTION I FOUND DEBRIS ON THE IPR SCREEN WHEN I PULLED IT OUT THIS TIME AS WHEN I PUT THE NEW INJECTORS IN IT WAS CLEAN AS A WHISTLE **
post #5 of 5 Old 08-16-2013, 07:35 AM Thread Starter
took the oil filter out and cranked it.. plenty of oil rushing into the filter reservoir and from where the hpop bolts on
waiting on a new hpop that I ordered took the old one off doesn't make any sound when I turn it
