Running a little "hot" after coolant flush. - Ford Powerstroke Diesel Forum
post #1 of 12 Old 08-11-2013, 07:34 PM Thread Starter
mrc228's Avatar
Recently I changed over from ford gold to the cat elc coolant. At that time I also did a restore full flush and back flushed the radiator, heater core and oil cooler. My delta was and still is well within the normal limits, typically 8 degrees on average.
My issue is this, prior to the coolant flush and changeover my ect's were 190-196 deg f. Post change the ect has risen to around 205 deg f under normal conditions and gotten as high as 216 while towing a 4k load. The ambient air temp has gone up a little from the upper 80's to the low to mid 90's here in Biloxi. The temp increase seems a bit high for the rise in outdoor air temp, is it possible that I have too much coolant and not enough water?
(The 216 deg ect was while using the canned sct tow tune. After loading TDP's tow tune the highest temp I saw was 209.)
Sent from AutoGuide.com App
'06 F250 CC FX4 - 127k miles
Under the hood
EGR Delete, Upgraded oil cooler, upgraded stc fiting /w new HPOP, Blue Spring, 4" Turbo Back, SCT tuner /w Wildman Extreme & Street tune, Sinister Diesel Coolant Filter
studs to come
In the cab
Pillar Glowshift gauge package (EoP/Fuel press/EGT), Dashboss
Alpine touchscreen nav head unit, bluetooth, Phoenix Gold 4-channel amp, JL Audio's 6.5 components up front, 5x7's in rear doors, 10" sub behind seats.
mrc228 is offline
post #2 of 12 Old 08-12-2013, 10:38 AM
Did you drain both sides of the block? If not then yoy might have more water than you think ( about 2 gal i believe) and might not be at 50/50. Below 50/50 you might have some cooling issues.
ajfrac is offline
post #3 of 12 Old 08-12-2013, 12:16 PM
Yeah, i was going to say, maybe you accidentally added too much water.??
MightyMouse75 is offline
post #4 of 12 Old 08-12-2013, 01:12 PM
Elc coolant has be shown to run hotter in these trucks. The gold coolant does keep cooler temps than elc
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #5 of 12 Old 08-14-2013, 09:30 PM Thread Starter
mrc228's Avatar
No I only drained the drivers side. Didn't feel like pulling the starter to drain the passenger side.
Under the hood
studs to come
In the cab
mrc228 is offline
post #6 of 12 Old 08-14-2013, 10:49 PM
KCCO!!
kells17's Avatar
Mine does the same. Especially if there is a lot of stop and go, ECT will jump to 203-208...never any higher, once i get going again, she will cool back down.
2004 F-250 Lariat CCSB
Studded, Deleted, Cold Air, Fog Light Mod,
IPR HF Coolant Filter, High Idle, Atlas 40 FICM,
CCV, Edge Insight CTS, ZooDad, BPD Oil Cooler,
4" Banks Monster Exhaust, Fumotos, 05 Harley Headlights,
Blue Spring, Kill Switch, 03 Turbo and 6.4 Banjo Bolts
VA Strokers
757 Diesel
kells17 is offline
post #7 of 12 Old 08-19-2013, 04:25 AM Thread Starter
mrc228's Avatar
Mine stays in the 203-208 range with eot's 6-8 deg f higher. I think it may be just my timing and the weather. It was cooler yesterday and the temp was the lowest I've seen at about 194. Oat was only high 70's and rainy. It's been mid to high 90's here lately.
Under the hood
studs to come
In the cab
mrc228 is offline
post #8 of 12 Old 08-19-2013, 05:53 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
I wonder if the RESTORE had a issue with the thermostat? Anyway they are real easy to change out. Id give that a try.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #9 of 12 Old 08-19-2013, 06:50 PM Thread Starter
mrc228's Avatar
I hadn't thought of that but it's worth digging into. I'll go ahead and replace the stat when I have a chance.
Under the hood
studs to come
In the cab
mrc228 is offline
post #10 of 12 Old 08-19-2013, 06:59 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
really? are there any other instances of this?
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
