Help fuel injection problems - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-11-2013, 01:06 PM Thread Starter
Silverbullet 6.0's Avatar
Truck died going down the road and won't start and I have a p2291 code on my sct it's a injector control pressure too low engine cranking is what it describes it as
Silverbullet 6.0 is offline
post #2 of 3 Old 08-12-2013, 04:14 AM
dxusmc's Avatar
What year is the truck? Will it start "cold" vs "hot" If it doesn't start in any condition sounds like your high pressure oil pump might have went belly up, but you can test to be sure if your air test your high pressure oil system.
If it just doesn't start hot, that air test will also point you in the right direction, but its most likely a STC fitting (05 and newer) or some other leak in the high pressure oil system.
2004 F250 XLT 6" lift, 37" tires, zoodad, T6,
edge cs, k&n, revx, warn lockers, rhino bars
future: coolant filter, headstuds, bluespring, 4" turboback, tires..dam these tires
Marines 2004-2009
Army 2009-2013
dxusmc is offline
post #3 of 3 Old 08-12-2013, 05:47 AM Thread Starter
