Ocassional differences in oil and coolant temps 15 to 16 degrees - Ford Powerstroke Diesel Forum
post #1 of 2 Old 08-11-2013, 08:25 AM Thread Starter
Most of the time my coolant and oil Temp differences are about 8 degrees. That's typically empty on the highway or pulling a 4500 lb trailer around town and on country roads. Recently I rented a 30 foot RV trailer and every so often when pushing it just a little I would see a rise in Coolant and Oil temps with a 15 to 16 degree difference. Wouldn't last more than a minute or so. Seemed like this would occur when the thermostat would open and coolant temps would drop quickly but the oil temps would remain almost unchanged. Didn't really push the truck cause it just wasn't necessary so most of the time I would see temp differences of about 8 to 9 degrees.
Truck has 107,000 miles on it and has had 2 coolant flushes during the course of the years and milage using the Ford Gold Coolant and staying on top of the modified Ford flush intervals and procedures. Getting close to time to be thinking about flushing again.
I've heard the use of evans coolant with no water will slowly remove some of the silicates that tend to be left by the Ford Gold coolant. Don't really want to replace the oil or EGR coolers unless absolutely needed.
Question 1) Do these temps sound normal?
Question 2) Would you switch to Evans coolant with no water at this point without replacing any oil or egr coolers?
Question 3) Should I get an SCT to simply shut the EGR valve off, no power mods?
Thanks for any and all help
06 F-350 psd cc lb FX4
NO MUFFLER!!!
ARP Head Studs
Coolant Filter
Scheaffers Oils
Gearhead CUSTOM 50hp Tow tune w/ trans tune & EGR off
Circuit Board Medics FICM
"STOCK" Binford 6100 Diesel w/ MORE POWER!
"I just wanted to see.............if ya'll wanted to buy a possum"
Fandini is offline
post #2 of 2 Old 08-11-2013, 08:51 AM
Ford_Fan1's Avatar
Quoted: 6 Post(s)
Feedback Score: 3 reviews
Well I can answer the first question. Those temps sound fine because the delta should always be based on driving 65mph down the highway with no load on. Since you had a load on it is normal for the delta to be greater than average for a period of time.
"Pickle Monster"
2004 F-350 King Ranch built 3/24/04
4" lift, 5" MBRP TB back exhaust
EGR MIA
,ported intake, 05-07 intake horn
CCSB
FX4
Firestone airbag suspension in the rear with on-board compressor
Monitored with Edge Insight CS, tuned by Gearhead
high idle mod, Atlas 40 FICM tune, Cat ELC,
2008 taillights, 08 mirrors, smoked marker lights, harpooned fuel tank, DIY headache rack, Bushwacker fender flares
Ford_Fan1 is offline
