Exhaust manifold bolt broken - Ford Powerstroke Diesel Forum
post #1 of 1 Old 08-10-2013, 12:31 PM Thread Starter
My '03 needs a new turbo Y-pipe bad (leaking drivers flex joint). While tackling that, I plan on installing an EGR delete up-pipe. I noticed that I have a broken exhaust manifold bolt on the passenger side (front most bolt on the bottom of the manifold). It has slight exhaust residue leaking from that area. I figured this would be a good time to just remove the manifold and replace ALL of the bolts and install a new gasket. Has anyone had to extract broken manifold bolts from there 6.0, and if so did it come out okay with an easy-out? How hard will the remaing bolts come out? The truck has 157,000 miles on it. Thanks.
SOLD--2003 F-250 RC/LB FX4, 6.0, 5R110, EGR cooler capped off at both ends, CAT EC-1, Rotella T6, Motorcraft fuel and oil filters, Amsoil in diffs/T-case, blue spring update, ScanGuage II, 5" Diamond Eye exhaust (not cat, no muffler
) 4" downpipe, Cooper Discoverer S/T's (LT265/75R16E).
rlu_tech is offline
