06 6.0 loosing power - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-09-2013, 02:17 PM Thread Starter
I have an 06 f-250 with an H&S, EGR delete, HPOP, rebuilt turbo, and 5in. the truck runs and starts fine untill you drive in for more then an half an hour or so. At which point the truck starts violently shaking. and when you let off the throttle to stop or pull over the RPM's drop to around 400 and will either jump back up and repeat or it will stall out. if it stalls the truck will not start back up unless i uninstall my tuner. It will throw a code P0299 i believe. i know this is for the injector but i had them replaced about 5k ago and once the truck cools down the code is not thrown until you either romp on it or highway drive for a half an hour or so. i just don't understand why it is so intermittent.
tedmiller is offline
post #2 of 6 Old 08-09-2013, 02:45 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Your tuner, was this a brand new tuner or one that was used that you bought from someone else or maybe one for another truck?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 6 Old 08-09-2013, 06:22 PM Thread Starter
I bought it brand new
post #4 of 6 Old 08-09-2013, 06:24 PM
Quoted: 50 Post(s)
Kind of sounds like an electrical problem. I'm thinking a chafed wire on the engine harness...
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDC Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #5 of 6 Old 08-09-2013, 06:33 PM
Smoke Eater
Feedback Score: 5 reviews
Send a message via Yahoo to fdchief
are you monitoring your ficm voltages?.... almost sounds like its dying a slow death when engine comp gets hot.... heat=resistance=if its weak it could cause it to die out... just a thought.. i could be way off here
2007 F-250 Lariat Crew Cab
SPL LED Lightbar
20" Fuel Rims
35" Nitto MT's
SCT Livewire w/ Tony Wildman Tunes
PMM Full EGR Delete/ Coolant Kit
Hornblasters 540 Kit
LED Lightiing All Around
All kinds of other Goodies!
2005 Lariat Crew- GONE!
2011 Lariat Ultimate Crew- GONE!!!
Back in a 6.0hhhhh and lovin it!
fdchief is offline
post #6 of 6 Old 08-10-2013, 06:18 AM Thread Starter
ya i just dont think its electrical because it only does it when i romp on it or on long drives. and my ficm is constant 48 volts. what about oil cooler?
Tags
6.0 injector , powrstroke
