03. F250 6.0 water in engine!!BAD. Need some help.please - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-08-2013, 07:34 PM Thread Starter
Exclamation 03. F250 6.0 water in engine!!BAD. Need some help.please
So here is the story. I bought a flooded truck from the auction. With the hope that the truck would not be flooded. But I was wrong.
The engine dip stick was a dark gray color oil passed the max line. Which is not good. I bought some engine cleaner from autozone, and allowed it to run for 10 min.
( the truck smokes white exhaust fumes when its running. Lots of white smoke)
I pulled it in the garage and I drained about 8 to 9 gallons of the water oil. Not good!!! I took off the oil filter and housing to clean it. Put a new filter.
After draining the oil I wanted to pull off the oil pan to make sure that there is no clay or mud at the bottom of the pan. (It took me like 5 hrs to take it off, clean it and to put it back without braking nothing. )
I put new oil. Started it up and still blows a lot of white smoke.
Is there something else??
The oil is still not very clean. So I am planning to change it again tomorrow.
But wanted some help on what I could do to make this truck run better.
Any advise?
Thanks.
But otherwise all the coolant and Tranny fluids are good.
theswed is offline
post #2 of 6 Old 08-08-2013, 07:36 PM
juniorssrollin's Avatar
Quoted: 2 Post(s)
Blown EGR cooler causing smoke?
Sent from AutoGuide.com App
2005 F350 CCLB FX4
juniorssrollin is offline
post #3 of 6 Old 08-08-2013, 11:12 PM
Keep the engine running, see if you are burming water, it could be diesel also
JorgeCanek is offline
post #4 of 6 Old 08-09-2013, 05:04 AM
I'd bet the intercooler is full of water too. Might wanna pull it and clean it.
Moto2four is offline
post #5 of 6 Old 08-09-2013, 07:52 PM Thread Starter
The intercooler is clean. I'll need find a egr delet and oil cooler. I would feel a lot better with my truck when I change that and the oil. Thanks for all the help.
theswed is offline
post #6 of 6 Old 08-09-2013, 08:36 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
All that nasty oil went through every injector also.
dhanna6powerstroke is offline
