Help Please!!! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-08-2013, 09:08 AM Thread Starter
IBStrokinit's Avatar
Help Please!!!
o5 f350 with 6.0
the egr let go and flooded crankcase with coolant. took heads off replaced gaskets, studded, and new oil cooler from sinister diesel. put heads back on tried to crank and it sounded horrible. took heads back off and found bent pushrods. sent heads to machine shop and they went through them and no cracks. replaced valvestem seals resurfaced and gave back. NOW I am ready to put everything back again...anything special I should know about this as far as timing and all? I have not touched cam or crank at all so I am trying to figure out why pushrods bent? Just need to get her back going...its been down for a month now..thanks for any help in advance!
IBStrokinit is offline
post #2 of 5 Old 08-08-2013, 01:48 PM Thread Starter
anybody??????
post #3 of 5 Old 08-08-2013, 02:14 PM
IIRC There is an index mark on harmonic balancer that need to be at the 6 o'clock position before the heads go back on. After you get one of the heads back on, manually rotate the motor and check for binding before installing the other head.
darenative is offline
post #4 of 5 Old 08-10-2013, 06:01 PM Thread Starter
63 views with one response...thanks guys..
post #5 of 5 Old 08-10-2013, 06:22 PM
Quoted: 50 Post(s)
This is the answer you need. The dowel mark on the dampener (between two of the bolts) needs to be at the 6 o'clock position before the heads go on. This is in case a lifter isnt compressed all the way, none of the pistons will be at TDC, preventing you from bending a pushrod agian. Unlike a gas motor, the heads on these motors have no combustion chamber, therefore a valve can kiss a piston during head reinstallation if a lifter doesnt compress all the way.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDC Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
