Died while running and now no start need help - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-07-2013, 08:09 PM Thread Starter
Hey guys I am new here and need a little help. I have a 2005 F350 6.0 I just put MBRP dual exhaust on it and gave it a little fuel to hear how the pipes sound and the truck just shut off and will not start. It will crank but not start, I just put a new FICM in it last week with a tune from ficmrepair.com, fuel filters have been change in the last week. I have a bullydog gt on the truck and it is showing no codes. I pulled off the secondary fuel filter cap and it has fuel it. Batteries have 12.8 volts.
stephen27925 is offline
post #2 of 10 Old 08-08-2013, 05:42 AM
dxusmc's Avatar
with no codes I'm a bit stumped, but there are lots of smarter folks here on the org so here's a bump
2004 F250 XLT 6" lift, 37" tires, zoodad, T6,
edge cs, k&n, revx, warn lockers, rhino bars
future: coolant filter, headstuds, bluespring, 4" turboback, tires..dam these tires
Marines 2004-2009
Army 2009-2013
dxusmc is offline
post #3 of 10 Old 08-08-2013, 05:53 AM Thread Starter
I hooked up my tuner and while trying to cranks I am getting 0 psi for the icp
post #4 of 10 Old 08-08-2013, 05:55 AM
dxusmc's Avatar
Try pulling the ICP harness off then try to start. It will set a default value for the PCM. If it starts, then you'll probably need a new ICP sensor and pigtail. If it doesn't start you'll want to do an air test and find out where your high pressure oil leak is.
Marines 2004-2009
Army 2009-2013
dxusmc is offline
post #5 of 10 Old 08-08-2013, 06:02 AM Thread Starter
Thanks just tried it and it didnt start looks like I will getting it towed to the shop to get them to run the test and see whats going.
post #6 of 10 Old 08-08-2013, 06:12 AM
dxusmc's Avatar
Was the ICP value 0 during cranking? If so sounds like the hpop might have somehow failed. If there was some pressure (just not enough) I'd think STC with your truck being a 2005. But before the air test, these are just guesses. Its just "0" is a scary number when it comes to the high pressure oil system.
Marines 2004-2009
Army 2009-2013
dxusmc is offline
post #7 of 10 Old 08-08-2013, 06:18 AM
jimmyv13's Avatar
Quoted: 46 Post(s)
Feedback Score: 3 reviews
Send a message via AIM to jimmyv13 Send a message via Yahoo to jimmyv13
What type of tuner do you have?
Most of the no start issues can be repaired in your driveway once the problem has been identified.
2005 F250 CCSB Lariat FX4
4" MBRP Turbo Back*Sinister Coolant Filter*SRL+*'10 Tailgate*Dicad EGR delete*Premium EdFICM*Powerslot Rotors*Hawk Pads*Riffraff boots*DIY CCV*ARP's*'10 Tails*N-FAB Steps*'12 Rear Bumper*Dashboss*Pioneer DVD*'08 Trans Pan
*Bullitt y-pipe*'14 PE PF Mirrors*Fox 2.0 IFP*'08 Diff Cover
jimmyv13 is offline
post #8 of 10 Old 08-08-2013, 06:41 AM Thread Starter
The icp value was 0. The turbo is stock
post #9 of 10 Old 08-08-2013, 12:50 PM Thread Starter
just found out it was the hpop so i am looking at 1500 thanks for yalls help!
post #10 of 10 Old 08-08-2013, 12:58 PM
dxusmc's Avatar
1500? mingya. Get that thing towed home, if you don't own tools, buy some, and buy the upgraded HPOP for like 800 and do it yourself. Add an oil change and filters to the mix and you're still way under 1500.
But I'm glad you found the problem, told you that "0" is scary
Marines 2004-2009
Army 2009-2013
dxusmc is offline
