Possible Turbo problem.... - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-04-2013, 07:19 PM Thread Starter
I have an 04 f350 and I am having a very recent boost/power issue that I could use some help with. I just got done pulling my boat back from the lake and stopped at a store for 3 minutes. Came back out, started the truck and now it wont build boost past 5 or so pounds and then blows massive amounts of black smoke. When the boost goes past 5 lbs it sounds like it is by passing. The truck has no unusual noises and seems to run smooth and normal. Not a diesel expert and I am learning as I go, so any help would be appreciated.
TruStang is offline
post #2 of 4 Old 08-04-2013, 07:33 PM
Deer Creek's Avatar
Quoted: 51 Post(s)
Check your boots at the CAC and the output side of the compressor. They sometimes have a tendency to blow off. Your turbo will still spool up but supply very little to no boost!
Ryan
Deer Creek Farm
Carthage, NC. 28327
2004 F250 4X4 6.0 Diesel "War Wagon"
SRW Crew Cab Long Bed Pushing 305,000 Miles
Running 5w-40 T6 with RevX
FICM PHP Eco Tune
Blue Spring MOD
Warren 175/30 Injectors
EGR Deleted & Studded
Dieselsite Adrenaline HPOP
Coolant Filtration System
MBRP 4" Turbo Back Straight Pipe
Bullet Proof Diesel Water Pump
Ranch Hand's Legend Front & Rear Bumpers
2" Rough Country Lift
SCT X4 Tuner
Nitto Terra Grapler 285/75/16s
Deer Creek is offline
post #3 of 4 Old 08-04-2013, 07:36 PM
Deer Creek's Avatar
Quoted: 51 Post(s)
And welcome to the ORG!
Ryan
Deer Creek Farm
Carthage, NC. 28327
FICM PHP Eco Tune
Blue Spring MOD
SCT X4 Tuner
post #4 of 4 Old 08-08-2013, 06:42 PM Thread Starter
Thank you! As for an update, it was the intercooler on the hotside. Missed it on my initial inspection and thats what sent me down the wrong path. Found when i started taking the piping off. Thanks again for the help.
TruStang is offline
