oil cooler cover emergency!!! - Ford Powerstroke Diesel Forum
post #1 of 15 Old 08-04-2013, 05:55 PM Thread Starter
Ok, long story short im doing studs and everythibg else, including new oil cooler. But 4 of the bolts are rounded out. Ive tried other sockets, wrenches, and even the reverse twist rounded bolt remover sockets. Anyone know some tricks for this? Thanks
ajfrac is offline
post #2 of 15 Old 08-04-2013, 06:32 PM
Cut the head off, pull it later with the vise-grip pliers.
JorgeCanek is offline
post #3 of 15 Old 08-04-2013, 06:48 PM Thread Starter
I would have to cut through the oil cooler cover, which would send shavings right into the hpop
ajfrac is offline
post #4 of 15 Old 08-04-2013, 07:02 PM
bubmiller's Avatar
Set a grade 8 nut over the bolt head and use a welder to melt them together. It will give you new flat sides for a socket, and the heat will help loosen the threads.
06 F250 CCLB
Bulletproof FICM
Sinister EGR Delete
Pypes Exhaust
ARP studs
SCT X3 w/Pro Racer
bubmiller is offline
post #5 of 15 Old 08-04-2013, 07:20 PM
Deer Creek's Avatar
Quoted: 51 Post(s)
Bam! Right on the money!
Ryan
Deer Creek Farm
Carthage, NC. 28327
2004 F250 4X4 6.0 Diesel "War Wagon"
SRW Crew Cab Long Bed Pushing 305,000 Miles
Running 5w-40 T6 with RevX
FICM PHP Eco Tune
Blue Spring MOD
Warren 175/30 Injectors
EGR Deleted & Studded
Dieselsite Adrenaline HPOP
Coolant Filtration System
MBRP 4" Turbo Back Straight Pipe
Bullet Proof Diesel Water Pump
Ranch Hand's Legend Front & Rear Bumpers
2" Rough Country Lift
SCT X4 Tuner
Nitto Terra Grapler 285/75/16s
Deer Creek is offline
post #6 of 15 Old 08-04-2013, 07:46 PM
drivininidaho's Avatar
Quoted: 87 Post(s)
great idea man!!!! just don't go too hot lol
Lyndel
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
'04 F25 SD CCSB
studded, and having some issues.....
drivininidaho is offline
post #7 of 15 Old 08-04-2013, 07:54 PM Thread Starter
Great idea, but sadly one of them is at the front of the cover next to the water pump area, wont be able to reach it with the welder.
My dad is mailing me a snap on bolt remover he said has never not worked. Im going to try that and if it doesnt work I think im going to get a filter kit. I already have egr cooler delete, but my deltas were hitting 24* and it cant be good to have oil getting that hot. Would the coolant filter prevent my deltas from getting higher?
ajfrac is offline
post #8 of 15 Old 08-22-2013, 07:43 PM
Quoted: 87 Post(s)
When are you hitting 24*? While towing up hill or just crusing? Mine are getting out if control. Way too hot.
Lyndel
'04 F25 SD CCSB
post #9 of 15 Old 08-22-2013, 08:15 PM Thread Starter
Well I was able to get the bolts out, using a snap on bolt remover. Ill never buy irwin brand tools again.
Thats was with a mild tune cruising flat hwy at 65mph no load. I already had the egr cooler delete so 24deg isnt really an issue, but if youve got youre egr cooler in tact you shouldnt be surprised if it blows at anything 20 degrees and above. New ford programming put in a new code for 15degree deltas to throw the wrench light and a P012F code. Definitely consider replacing it. And do and egr cooler delete while youre in there.
468 HP & 873 Ft-Lbs
2005 F-350 SRW 4x4 CC Long Bed
SPD tune by Chris @ Truck Source Diesel
ARP Head Studs
3.5" DP to 4" Straight Pipe
Banks High Ram Air Intake
K&N CAI
Edge Evo CTS w/ Backup Camera to monitor
MTS HD Direct Drive Solenoid
Updated:
Standpipe & dummy plugs
Turbo feed & drain tubes
HPOP & IPR screens
Blue Spring
ajfrac is offline
post #10 of 15 Old 08-22-2013, 11:46 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Just so you know, your engine oil being over 240-250 isn't a bad thing if your towing heavy thru the mountains. The only reason there is a 15*f delta is because that tells you if your oil cooler is getting plugged. Of course this has to be unloaded on flat ground. Lots of guys run their oil - coolant way above 15*f but that's only while towing and once you hit flat ground it should drop back down. Even with my BPD air-oil cooler pulling 16k I see my oil go up to 230+... Jetjock has seen his temps 250*f+ for several hours srtaight with no ill side effects.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
