Where does this plug into? Is it related to my no start situation? - Ford Powerstroke Diesel Forum
post #1 of 18 Old 08-04-2013, 04:26 PM Thread Starter
Background information. I purchased the truck about a month ago. For some reason it takes about 6 seconds or so to start at all times whether cold or hot. First start up it runs a little rough (not bad but just a little). The only mods are 4" turbo back exhaust, EGR delete and that's it. Last week I left out and felt the truck running a little rough, turned around and went home and it died in the driveway. It spins over, doesn't start oil pressure gauge doesn't move at all while the motor is spinning. Has fuel in the fuel bowl. Good FICM volts. Had an Edge Juice when I purchased it however I removed it since it did nothing for the truck. The truck is a 2005 with 75,600 miles.
First question, what does this plug into?
Scangauge II view while cranking:
Scangauge II view just key on:
Battery volts are a little low (11.9v) from diagnosing and turning the truck over. However it isn't the issue, they are new Motorcraft batteries.
RED CTD is offline
post #2 of 18 Old 08-04-2013, 04:30 PM
roche837's Avatar
Quoted: 5 Post(s)
Garage
Feedback Score: 4 reviews
Looks like your mass air flow plug..... Your going to want that plugged in. Should be on intake tube
EMPIRE STATE STROKERS
Studded, 5" exhaust, Sinister EGR DELETE / Coolant Filtration, more to come
roche837 is offline
post #3 of 18 Old 08-04-2013, 04:32 PM
Yep that's the maf connector, I don't think it will cause a no start but anything is possible.
2006 White F350 CCLB 2WD
dowmace is offline
post #4 of 18 Old 08-04-2013, 04:34 PM Thread Starter
Lol I swear I looked everywhere for the plug except the MAF. It even looks like a MAF connector now that I look at it again.
RED CTD is offline
post #5 of 18 Old 08-04-2013, 04:40 PM
squirtgun's Avatar
The no start could be a high pressure oil leak.Hpop or injector o-rings
2003 6.0L F250 4x4 Lariat
Fog Light Mod,High Idle Mod,Zoodad,Hose clamp taligate mod,08 rear bumper,Sinister EGR delete,ELC EC-1 coolant,Edge Juice,MKM(Sinister)coolant filter,HFCM drain plug upgrade,diy FICM repair(steady 48.5v now),DIY CCV mod,Torque Pro,Blue spring upgrade,Aluminum radiator,05 headlights,LED foglightd
Wish List/Things to do
Y-pipe,fuel pressure gauge,diy oil bypass(maybe centrifuge),oil pressure gauge
squirtgun is offline
post #6 of 18 Old 08-04-2013, 04:45 PM Thread Starter
No MAF on this truck. If I remember correctly the MAF on this truck is just inserted in the intake tube.
RED CTD is offline
post #7 of 18 Old 08-04-2013, 04:46 PM
My 2005 has the same plug, not plugged and no Maf. I think it's actually an Air intake temp sensor. From what I gather these have different strategies that rely on other sensors like ebp and others to make fuel decisions. From your first scanguage pic your ipr is open wide and its still not reading icp enough to crank. You can try unplugging the icp sensor to see if its failed but if not you have a major hpo leak.
2005 F-250
FX-4 Manual Trans
MBRP duals
Coolant Filter
CCV Mod
Leveled, American Racing Mojaves Nitto Terra Grapplers
Looney
Livewire
Scangauge II
reilly828282 is offline
post #8 of 18 Old 08-04-2013, 04:49 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
ICP when cranking needs to be over 500psi. Looks like the IPR is trying to open, but isn't giving the ICP enough oil psi to reach 500psi.
Are you running aftermarket oil filters?
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #9 of 18 Old 08-04-2013, 05:35 PM Thread Starter
No, factory oil filter. Tried unplugging the ICP and still no start, just threw the P2285 code.
RED CTD is offline
post #10 of 18 Old 08-04-2013, 05:41 PM Thread Starter
I guess I'm looking for a leak at the HPOP.
RED CTD is offline
