Glow plug pin-out - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-03-2013, 07:44 AM Thread Starter
stillstroken's Avatar
Glow plug pin-out
Does anyone have a glow plug pin-out?
Here is my issue. When you first start the truck and the engine is cool it buck's and kicks like you wouldn't believe. Once the engine warms, it is fine. No codes, I've done and injector cut out and no issue found (when warm). I'm at my wits end. Could it possibly be loosing prime over night or after it sits awhile as well? I am going to test my FICM and glow plug harness but I am wondering if anyone has a pin-out of the harness so I don't go poking injector solenoids.
Truck has 90k ARPS, and had a new EGR cooler and Oil Cooler done at 50K. Filters all changed 2k ago.
Thanks for the help.
2005 F-250 6.0
4" Superlift w/ rear air bags
ARP Head Studs
K&N Air Filter System
CFM Intake Elbow
Flow Pro Exhaust minus Muffler
Hypertec Max Energy
Isspro Guages...Pyro, Boost, Trans Temp, Voltage
stillstroken is offline
post #2 of 7 Old 08-03-2013, 12:55 PM
Ford_Fan1's Avatar
Quoted: 6 Post(s)
Feedback Score: 3 reviews
what is a glow plug pin-out?
"Pickle Monster"
2004 F-350 King Ranch built 3/24/04
4" lift, 5" MBRP TB back exhaust
EGR MIA
,ported intake, 05-07 intake horn
CCSB
FX4
Firestone airbag suspension in the rear with on-board compressor
Monitored with Edge Insight CS, tuned by Gearhead
high idle mod, Atlas 40 FICM tune, Cat ELC,
2008 taillights, 08 mirrors, smoked marker lights, harpooned fuel tank, DIY headache rack, Bushwacker fender flares
Ford_Fan1 is offline
post #3 of 7 Old 08-03-2013, 04:32 PM
dxusmc's Avatar
FICM by itself could cause this problem. If the FICM tests good, when is the last time you had the truck reflashed? Ford has some enhancements to cold start issues. Also maybe try an oil additive like RevX, might have some stiction issues. But when my FICM was going bad, cold starts were a beast, then it had to be plugged in for like 4 hours. Readings were good, ended up having a bad logic side. Had to put a known good one to pinpoint the problem
2004 F250 XLT 6" lift, 37" tires, zoodad, T6,
edge cs, k&n, revx, warn lockers, rhino bars
future: coolant filter, headstuds, bluespring, 4" turboback, tires..dam these tires
Marines 2004-2009
Army 2009-2013
dxusmc is offline
post #4 of 7 Old 08-04-2013, 07:56 AM Thread Starter
How did yours run warm? Did it happen to kick every once in awhile at low rpm cruise speed under load? Mine doesn't have a hard time starting, at least yet!
2005 F-250 6.0
ARP Head Studs
CFM Intake Elbow
Hypertec Max Energy
post #5 of 7 Old 08-04-2013, 08:21 AM
dxusmc's Avatar
when it was warm, at like highway speeds it would feel like I lost an injector or 2 without the smoke..loss of power, bucking. If I got on the skinny pedal again it would smooth out. Basically in OD it was gutless, thats when I started to realize I had a serious issue going on. At first I thought the hard starts just might be glow plug related
Marines 2004-2009
Army 2009-2013
dxusmc is offline
post #6 of 7 Old 08-04-2013, 10:13 AM
I had same exact symptoms, needed new ficm ( make sure you test it cold), and T6 5w-40 with archoil, now just T6 in the oil and its fine.
ajfrac is offline
post #7 of 7 Old 08-04-2013, 03:36 PM Thread Starter
I'm going to test it Saturday morning. I'll let y'all know my findings.
2005 F-250 6.0
ARP Head Studs
CFM Intake Elbow
Hypertec Max Energy
