Need help. Stranded!! - Ford Powerstroke Diesel Forum
post #1 of 32 Old 08-03-2013, 02:00 AM Thread Starter
powerstrokecrzy's Avatar
Quoted: 255 Post(s)
Stranded on way to beach someone knowledgeable help quick. Truck started stuttering going down the road. Pulled into rest area. Code read po261-injector one circuit low and p2290. More truck won't start back. Ficm reads 48v. Ipr % jumps to 84 when trying to start. Can't get a hpop reading cause the starter I put on a week ago has crapped out on me. Got it off and will be at the auto parts store when they open. I have people with me to help luckily.
05 250. Lariet. 4x4.
arp studs w/oem gaskets & all updates
Warren 175cc/stock sticks
Egr delete
Zoodad
New oil cooler
Coolant filter w/ zerex ec-1(homemade)
4" turbo back, straight piped
SCT livewire (running TSD SPD)
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Ccv reroute (dump to atmosphere)
Air Horn Kit
high idle
Pro comp "bullet hole style" 17" w/ 35" nitto trail grapplers
powerstrokecrzy is offline
post #2 of 32 Old 08-03-2013, 02:17 AM Thread Starter
Quoted: 255 Post(s)
It has the updated stc, updated stand pipes and dummy plugs. if ipr% is jumping so high right off the bat, could it be the the ipr?
Egr delete
Zoodad
New oil cooler
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Air Horn Kit
high idle
post #3 of 32 Old 08-03-2013, 03:18 AM
Unplug your icp and see if it will start. Computer will use a default value to start. The PCM has to see 500psi min before it will let the injectors to fire.
Ipr will useually go to 84% at first to try to divert as much oil pressure in the rail as possible to make it easier to start and will then open back up to bypass excess oil.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #4 of 32 Old 08-03-2013, 04:56 AM Thread Starter
Quoted: 255 Post(s)
Ok, got it to start. Went and got a new starter. Guessing maybe starter wasn't allowing it to turn fast enough. But still have miss. Same codes as before along with po263. Has number one injector just gone bad or what? I'm able to go now and gonna try to limp to the beach and fix there. Warren just done these injectors 3 months ago. Whats the chances he will help me out here?
I always run t6 with hss at every oil change and additive in fuel.
Whats the chances I blew the o rings on #1 injector and that is giving me the p2290? Running down the road my ipr% and icp are perfect. Hitting right at 4000 psi at wot, just the miss of #1 injector.
Thanks for the reply.
By the way, this is the second starter in 6 days, third in 10 months. Way to sell quality parts advanced auto!
Egr delete
Zoodad
New oil cooler
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Air Horn Kit
high idle
post #5 of 32 Old 08-03-2013, 10:27 AM Thread Starter
Quoted: 255 Post(s)
Update: made it to where I was going. Cut truck off there won't restart. When trying to crank the most icp it builds is 289 psi, ipr goes to 84%. Unplug the icp sensor and it will crank. so hpo leak somewhere. Also injector #1 still not working. Could icp and injector be related cause they both happened at same time. Before this not even a hiccup in it's day to day operation. Ideas please guys, I'm 6 hours from home in virginia beach gotta get this thing fixed before I pull home next saturday.
New updated stand pipes and dummy plugs. Stc fitting a couple years ago. never had a sensor or regulator. Help help!!!
Egr delete
Zoodad
New oil cooler
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Air Horn Kit
high idle
post #6 of 32 Old 08-03-2013, 11:24 AM
Sounds like your blew the oring on top of the number 1 injector. Either that or the nozzle going into the oil rail is leaking hpo out. I wouldn't be surprised if the two aren't a coincidence and they are related. Pull the pass valve cover and oil rail and if the nozzle is really loose that oring may be bad. While it is off check the oring on top of the #1 injector as well.
2005 F-250
FX-4 Manual Trans
MBRP duals
Coolant Filter
CCV Mod
Leveled, American Racing Mojaves Nitto Terra Grapplers
Looney
Livewire
Scangauge II
reilly828282 is offline
post #7 of 32 Old 08-03-2013, 11:44 AM Thread Starter
Quoted: 255 Post(s)
Could you elaborate on the oil rail nozzle o ring, a pic would be good. I know they're there just never messed with the nozzle o ring. Just want to know what to expect going in.
Egr delete
Zoodad
New oil cooler
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Air Horn Kit
high idle
post #8 of 32 Old 08-03-2013, 02:37 PM
The oil rails have nipples that should be fairly stiff to move or not move at all. The nozzles carry hpo to your injector spool valves. They are mounted in the oil rail and have a replaceable o ring. Also on the top of the injector itself there is an oring that seals to the outside of the nozzle. When you install the oil rail you will feel them seat. Google 6.0l oil rail nozzle oring, and injector hpo oring.
2005 F-250
FX-4 Manual Trans
MBRP duals
Coolant Filter
CCV Mod
Looney
Livewire
Scangauge II
post #9 of 32 Old 08-03-2013, 05:03 PM Thread Starter
Quoted: 255 Post(s)
Would that one seal being bad cause a hot no start. It'll start cold or with icp unplugged
Egr delete
Zoodad
New oil cooler
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Air Horn Kit
high idle
post #10 of 32 Old 08-03-2013, 05:18 PM
I probably wouldn't think it was except for the injector misfire as well. Here is a good article to read
6.0L ICP System Leaks - DTS Articles - Articles - Articles - DTS
2005 F-250
FX-4 Manual Trans
MBRP duals
Coolant Filter
CCV Mod
Looney
Livewire
Scangauge II
